Dash removal - Mustang Evolution
Old 05-19-2013, 01:53 PM   #1
sam62893's Avatar
Dash removal
Does anyone know if I have to remove the dash to install another wiring harness? It is there a way around that? If I can't do it without taking out the dash, how is the dash taken out? 97 V6. Installing a new edge wiring harness
Old 05-19-2013, 04:18 PM   #2
Sluder4's Avatar
If its anything like the 99/04 then you just take out the middle console. It's a pain in the *** to do but easier than taking the dash off.
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 05-19-2013, 04:30 PM   #3
sam62893's Avatar
Center consoles out, but I have to replace the computer and all the wires there. I was wondering about those
Old 05-20-2013, 06:04 PM   #4
samuelsmith's Avatar
Easy as abc.
The computer is at the top right of your pic. Under the passenger kick panel.
Old 05-21-2013, 01:06 AM   #5
sam62893's Avatar
Originally Posted by samuelsmith View Post
Easy as abc.
Thanks, it's a PITA... It's friggin midnight and I still haven't taken the cables out. I'm jus gonna wait till tomorrow to finish up.
Old 05-21-2013, 02:37 PM   #6
Holy smokes!?!!?!!! Consider installing a new heater core while you have it apart. Unless you think removing that dash is fun...
Old 05-21-2013, 04:00 PM   #7
sam62893's Avatar
no, I'm not trying to spend any money on this build. The car isn't for me, it's a project that I'm just going to swap engines and sell. More of a learning experience to get to know my car better as well
Old 05-21-2013, 05:20 PM   #8
[QUOTE=sam62893;1658925]Thanks, it's a PITA... It's friggin midnight and I still haven't taken the cables out. I'm jus gonna wait till tomorrow to finish up.
old you take a picture of the heating element? SO I know how hard it is to get to. Many cold winters ahead if I am lazy.
Old 05-21-2013, 06:19 PM   #9
sam62893's Avatar
I don't know where the heater core is at. I haven't pulled out the dash all the way yet. I'm going to trace the old wiring harness and put inch in the new one. I've had a couple of the "crap where does this go again?" Moments already
Old 05-21-2013, 09:42 PM   #10
I found the heating element. Its in the heater core which is on the passenger side below the air bag. I think, it should come out without removing the dash.
I was going to show you a picture but failure.
Old 05-24-2013, 11:11 PM   #11
sam62893's Avatar
I still haven't removed the while dash
Old 05-25-2013, 03:42 PM   #12
Take pictures of everything. So you have a reference when you put it back together.
Old 05-25-2013, 04:14 PM   #13
sam62893's Avatar
Yep, I did. Everything that came off I used masking tape to keep the screw or nut in place
03:37 PM
