So my buddy that traded me his mustang says that the rear bearings are bad. Whenever I go past 20 or 30 mph I heard a loud drone coming from my rear and it only happens when I accelerate. I thought it was the exhaust but he assured me it was the bearings. Is it the bearings or could it be something else?
Also, if I have to replace the bearings can I just jack up the car on the rear wheels, drain diff fluid and insert new fluid with the car on the ground? Or does it have to be on 4 jack stands? I've never put fluid in the diff
If the bearings are bad, it was more than likely due to a bad gear install. You'll need a complete gear & install kit. It's not a job anyone can do, on scale 1-10, its an 8+.
It would be far cheaper to find a complete rear end at a junk yard. To fix you could be looking at $1000. Replacing the whole rear end would also be something you could do yourself. This is only a guess, but I'd think you could find one for $1-300.
It's probably an axle bearing. I just had one go out on my car. You described the noise that it was making exactly. It took the axle out with it, so I upgraded to a new posi and 31 spline axles on my. 8.8. If it is an axle bearing, be careful driving it like that. The axle could possibly break...
I've been abusing the acceleration for a while. I guess I'll lay off until I get my new axle, thanks. And the GT 8.8 has t-lock right?
I think it's my lucky week next week. I called and they said that the whole axle is sold for $160 + $20 for core charges or something. And they also told me that the 27th is 50% off and I don't have work that day. Can you say lucky?
Yeah ,I know. Thanks for telling me that because I've been accelerating pretty hard lately. So I'm gonna lay off for a while. Guess ill have to grandma drive. Wouldn't want my wheel to pop out in the freeway. I'm actually kind of glad though. Gives me an excuse to upgrade thanks!
After you get it apart you need to heat the bearing up and beat it off with a hammer. Shove the 2 shafts in a fridge for a few hours and press the bearings back on. Need machine press. It is easier to get a recycle center rear end.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
