help - Mustang Evolution
Old 05-24-2013, 02:49 PM   #1
Anthony8994's Avatar
help
I have a popping noise coming from the front driver side every time i hit the gas from a stop I cannot find it there's nothing lose anybody got any suggestions?
Anthony8994 is offline   Reply With Quote
Old 05-24-2013, 02:52 PM   #2
Venomouz831's Avatar
Is it coming from the header area? On idle rev it up and see if the noise gets louder
)02 Gt, Founder of WE2G
Old 05-24-2013, 03:11 PM   #3
if I'm in neutral or park it does not make a sound only when I'm in drive stopping for a light but it is every time I stop sounds kinda like it's coming from the inside of the rotor area I'm not sure exactly it's hard to tell exactly because I can never hear from outside
Old 05-24-2013, 09:35 PM   #4
Xaperez100's Avatar
It's probably a spark plug. Get out with the car on open the hood and pull the throttle cable to see if you can hear it and see it when you pull it
Xaperez100 is offline   Reply With Quote
Old 05-24-2013, 09:53 PM   #5
sam62893's Avatar
it could be a bad plug as well. or yo have a friend drive it in front of you with the good open so you can pinpoint the sound better
Old 05-25-2013, 12:38 AM   #6
no its definitely not a spark plug is metal on metal contact it sounds like a body mount or something like that not sure tho
Old 05-25-2013, 12:59 AM   #7
sam62893's Avatar
Maybe something's loose? Check your battery, do you have HID's? It could be a loose ballast. Or motor and tranny mount.
Old 05-25-2013, 01:13 AM   #8
I don't have HID's and I know its not a motor mile I don't know how to check if its a tranny mounts to be sure or what else I should look for
Old 05-25-2013, 01:48 AM   #9
sam62893's Avatar
Maybe your battery is loose. But here, I snagged these off google a tranny mount looks like this
It should be right before the tail of the tranny, before it attaches to the driveshaft. Jack up the car and look under it. Check for wear and tear
Old 05-25-2013, 02:17 AM   #10
Xaperez100's Avatar
Try pushing down on your car it could be one of your struts
Old 05-25-2013, 02:30 AM   #11
sam62893's Avatar
My struts are shot and I don't hear a metal to metal bumping sound. OP, does the sound come ink when you press in the gas or when you turn the wheel?
Old 05-25-2013, 02:36 AM   #12
Xaperez100's Avatar
My friends gt's struts are bad and they make a lot of noise
Old 05-25-2013, 02:38 AM   #13
sam62893's Avatar
Yeah they make a creaking noise but never a metal to metal hit. Unless something broke off and the strut is hitting the frame?
Old 05-25-2013, 02:48 AM   #14
Xaperez100's Avatar
Yeah it's his tower brace
Old 05-25-2013, 07:45 AM   #15
I don't think so much towers are in pretty good shape to the fairly new
Old 05-25-2013, 01:31 PM   #16
Region: Iowa
Ball joint , sway bar bushings ,tie rod ends , cool spring mis aligned
Iowaboy13 is offline   Reply With Quote
Old 05-25-2013, 03:49 PM   #17
samuelsmith's Avatar
There is a rubber boot between the spring and the frame. If it goes bad it makes plenty of noise.
Old 05-25-2013, 04:20 PM   #18
Countryboy2523's Avatar
Region: Arkansas
Had you looked over your brake shoes when they get low enough they will make the metal on metal noise even when your not on the break petel
Countryboy2523 is offline   Reply With Quote
Old 05-25-2013, 08:06 PM   #19
Vsixpower's Avatar
It could be bad cv joints do they click when u turn or when ur driving
Vsixpower is offline   Reply With Quote
Old 05-25-2013, 10:47 PM   #20
...really?
Old 05-25-2013, 10:51 PM   #21
Vsixpower's Avatar
Ya I know
Old 05-25-2013, 11:14 PM   #22
Vsixpower's Avatar
02:01 AM
