Cigar lighter problem ! - Mustang Evolution
Old 05-24-2013, 09:11 PM   #1
Toolbox20's Avatar
Exclamation Cigar lighter problem !
I have had this problem since ive owned the car , almost a year now !
Neither of the cigar lights worked , no idea on how to get them to work , checked all fuses , they all seem to be fine , still nothing !
No power running to the socket ! dont know what to do .
Any ideas ? !
Toolbox20 is offline   Reply With Quote
Old 05-24-2013, 09:18 PM   #2
sam62893's Avatar
Wire could be frayed or torn. You're going to have to trace it as far as you can without removing the dash. I know the one in my center console doesn't work. I've taken out the center console and trace the wire, but no luck. It could be the lighter itself. You could try buying one at autozone or something and replace it to see if that's the problem. That was the problem in my ex mother in laws car. I crimped some new female connectors and got a new lighter and it worked perfectly
Old 05-24-2013, 11:40 PM   #3
Toolbox20's Avatar
I pulled out all fuses and put them back it , took my power tester an they both had power , put it all together , an they still worked , til I started the car an they stopped working .
An I don't have a stereo in my car right now , so the wires that are used to hard wire to a stereo , I taped them so no wires are exposed , an then the sockets started working , then I started it an it stopped .
Would it have to do with my battery ?
Cause my battery is slap dead , barely holds charge to it . I have to jump it off .
07:23 PM
