Missing on hot startup. - Mustang Evolution
Old 05-28-2013, 06:39 PM   #1
Robbiemustang96's Avatar
Why does my 98 V6 miss when i start it and its warm. Like 210 warm. If i like go somewhere and park it and shut it off, and go back to start it again it starts right up but it misses.. Why does it do this
Robbiemustang96 is offline   Reply With Quote
Old 05-30-2013, 09:10 AM   #2
Bump
Old 05-30-2013, 12:29 PM   #3
kickerofdoom's Avatar
Tune up maybe
Old 05-30-2013, 12:33 PM   #4
Just did one.. New sparks new air filter.. Maybe i need to change the fuel filter and put some more coolant in... Idk maybe needs some new plugs a performance coil pack. But i need money!! Ugh... Being a 16 year old with a car is hard... Maybe it needs a new fuel pump... Cause this car has 173XXX miles on it..
Old 05-30-2013, 04:18 PM   #5
Oil change , spark plugs and wires
Old 05-30-2013, 05:30 PM   #6
I found out why its been gettin so hot. When i installed my gauges in my dash i had to disconnect the temp sending unit to put in the other temp sending unit to my gauges in my dash and not knowing that it controls the fan.
Old 05-30-2013, 05:40 PM   #7
BattleBorn's Avatar
Region: Nevada
Good, for a second it almost sounded like a bad fuel pump.
BattleBorn is offline   Reply With Quote
Old 05-30-2013, 05:45 PM   #8
Im glad it wasnt! Do you know if someone makes a T pipe small enough so i could hook up both sending units?
Old 05-30-2013, 09:24 PM   #9
BattleBorn's Avatar
Region: Nevada
I'm not sure, check out americanmuscle.com or try googling it
« Help | v6 for v6? »
03:34 PM
