Fog lights - Mustang Evolution
Old 05-29-2013, 08:24 AM   #1
Blovett55's Avatar
The next step in my front end is to put smoked out fog lights in, the only problem is I have the small grills where the fog lights go
So I was wondering when I crawl under or take front bumper off, is this actually part of the front bumper or are they just inserts and are the screw holes still there on the sixxers to install fog lights
I just need to know if I need to cut the grills out which will most likely need bumper pulled off or not
Also the cobra sockets on AM have 2 wires coming out, is it possible to splice existing fog light power wire on my headlights and tie power in there then ground it somewhere
One last question is about hids, and Ik slosix atleast will be able to answer this
I've never done hids before, have smoked headlights, think I want to convert to hids, what kit and from where do I need
Basically from pics it looks to be part of the bumper
Blovett55 is offline   Reply With Quote
Old 05-29-2013, 08:29 AM   #2
SpeedyG's Avatar
You gonna have to cut those grills oit
SpeedyG is offline   Reply With Quote
Old 05-29-2013, 08:32 AM   #3
Blovett55's Avatar
How do you suggest that will look best
Old 05-29-2013, 08:49 AM   #4
Mustangdust's Avatar
I used a dermal with a cut off wheel
Mustangdust is offline   Reply With Quote
Old 05-29-2013, 08:53 AM   #5
There the black out one I got
Old 05-29-2013, 08:54 AM   #6
Blovett55's Avatar
Yeah I'm getting the smoked from AM
---------- Post added at 08:54 AM ---------- Previous post was at 08:54 AM ----------
What about the bolt up, do ours still have the bolt holes for fog lights
Old 05-29-2013, 09:00 AM   #7
Yes ill take pic when I can but only thing diff between v6 and gt is the fog grill
Old 05-29-2013, 09:02 AM   #8
Blovett55's Avatar
Awesome so how did you wire them into ur lighting system
I don't understand if ud put the bolt holes there why you would put grills of vise versa but I guess ford has done much more stupid things
Old 05-29-2013, 09:06 AM   #9
I run there own fuse and switch I put a hole in the dummy switch in the dash where the factory fog light switch is
Old 05-29-2013, 09:08 AM   #10
Blovett55's Avatar
Have you ever tried what I said about using your existing fog light power wire, I see no reason y it wouldn't work
Old 05-29-2013, 09:26 AM   #11
I never have but someone on here Probly has
Old 05-29-2013, 09:37 AM   #12
http://www.vmptuning.com/pdf/0104MB%202.0.1.pdf
Old 05-29-2013, 08:06 PM   #13
Blovett55's Avatar
Thanks, see I really want to have it tied into the existing light switch though, but that deff gave some insight into it
---------- Post added at 08:06 PM ---------- Previous post was at 08:04 PM ----------
Still need hid advice too
Old 05-29-2013, 08:11 PM   #14
sam62893's Avatar
Do you want HID for the fogs or headlights?
Old 05-29-2013, 08:11 PM   #15
Blovett55's Avatar
Headlights
Old 05-29-2013, 08:16 PM   #16
What light switch the headlight one??
Old 05-29-2013, 08:19 PM   #17
Blovett55's Avatar
Yeah, uk pull out half, fog lights on the side of the headlights come on(or depending we're your from, day time running lights) I want the fig lights to come on at same time
Old 05-29-2013, 08:23 PM   #18
You could splice the running light wire and add in the fog wires on each side
Old 05-29-2013, 08:26 PM   #19
Blovett55's Avatar
That's what I figured and just ground somewhere
Any idea which wire is power
Old 05-29-2013, 08:30 PM   #20
sam62893's Avatar
Headlights
DDM tuning
Here's what I got because I have smoked headlights
Old 05-29-2013, 08:31 PM   #21
sam62893's Avatar
Sorry forgot the picture
ID:	111124   Click image for larger version
Old 05-29-2013, 08:33 PM   #22
Blovett55's Avatar
How much does this run you
Old 05-29-2013, 08:38 PM   #23
sam62893's Avatar
$60 total because shipping from china
Old 05-29-2013, 08:43 PM   #24
Blovett55's Avatar
Oh not to bad, how bright, I'm running smoked lights with the upgraded raxiom bulbs
Old 05-29-2013, 08:44 PM   #25
sam62893's Avatar
Way better than OEM bulbs in the stock housing ill tell you that. I am really happy with the light output. Bad thing is no hi-beam. You'd have to pay extra for that, I think $10 more
Old 05-29-2013, 08:45 PM   #26
I believe it brown wire but one says major and one says minor you want the minor one , it will say it on the plug going in to the light bulb (orange bulb)
Old 05-29-2013, 08:47 PM   #27
Blovett55's Avatar
I drive out of town alot, deer everywhere so will need hibeam
---------- Post added at 08:47 PM ---------- Previous post was at 08:46 PM ----------
So minor is power correct
Old 05-29-2013, 08:48 PM   #28
sam62893's Avatar
If I could go back, I would get hi's. I'm sure the deer will get heart attacks once you turn up your lights
Old 05-29-2013, 08:59 PM   #29
Blovett55's Avatar
Haha yeah iv never had one step out on me but their common in woods round me,
I'd assume turn my flashers on take my rifle out and chase down the deer, did it in our suburban before
Love deer season
---------- Post added at 08:55 PM ---------- Previous post was at 08:51 PM ----------
What is the bulb color for the hids for
---------- Post added at 08:59 PM ---------- Previous post was at 08:55 PM ----------
No hid harness eliminators or cables needed for our mustangs?
Old 05-29-2013, 09:30 PM   #30
sam62893's Avatar
Love deer season
Wabbit season...
Bulb cornis confusing, but lower is yellower and higher is whiter. 6k gets you a nice blue 3k gets a good yellow and 10k gives yo bright white and there's all the in betweens. Nope, it's just plug and play. The stock harness connects to the ballasts and the ballasts connect to the HID's pretty easy
Old 05-29-2013, 09:37 PM   #31
Blovett55's Avatar
Wabbit season...
Yeah don't hunt much rabbit will alittle for rabbit stew, don't eat rabbit alot because of rabbit starvation if we ate that alone for awhile
So I'm looking at bout $60
Ill deff have some more questions when I get it
Old 05-29-2013, 09:41 PM   #32
sam62893's Avatar
Duck season.... Haha bugs bunny man. Don't know anything about hunting though.
Yeah $70 maybe because of the hi-beams. I think you will. It's basic plug and play. Then you have to connect the ballast a different way because of reverse polarity or something like that. But you'll see when you get them
Old 05-29-2013, 09:45 PM   #33
Blovett55's Avatar
Yeah only do duck hunting 1 day a year, ill have all mine shot in one day
So here's the set up
62 bucks
And the eliminator has this for reverse polarity
So should you get this
Old 05-30-2013, 11:00 AM   #34
Torchredmustang's Avatar
Personally, I'd recommend clear fogs over dark ones IF you're after better light output.
Torchredmustang is offline   Reply With Quote
Old 05-30-2013, 11:05 AM   #35
Blovett55's Avatar
No, I have smoked headlights so just looking to match
10:53 AM
