split port swap - Mustang Evolution
Old 05-29-2013, 01:12 PM   #1
mummert_96v6's Avatar
split port swap
I have a 96 mustang v6. And I want to do a split port swap. What all do I need to do the swap?
mummert_96v6 is offline   Reply With Quote
Old 05-29-2013, 08:21 PM   #2
Fourloko530's Avatar
I'm thinking bout doing it to
Fourloko530 is offline   Reply With Quote
Old 05-29-2013, 08:29 PM   #3
What all do I need to change though? The whole motor and engine bay harness? Or can I just change the top end? And does the harness have to be changed?
Old 05-29-2013, 10:18 PM   #4
lemons95's Avatar
I think you can keep the harness, but you would need a 99 lower intake. They had some sorta valves that need the newer computer too control them, but 99 didn't have them.
You also need a windstar fuelrail.
Theres probably more i'm forgetting about.
Old 05-30-2013, 12:42 PM   #5
Well i know you would need the heads and upper and lower intake. But Idk if you need to change the harness
Old 05-31-2013, 05:25 PM   #6
Ghostedmind's Avatar
The valves are the Intake Manifold Runner Control (IMRC) valves
LCMC Member
04:26 AM
