Transmission Question: 1997 V6 Automatic Transmission ?? - Mustang Evolution
Old 11-24-2003, 12:33 AM   #1
I own a 1997 Ford Mustang V6 3.8L with 71K miles, automatic transmission.
I have been experiencing performance problems with the car, specifically when I am accelerating on the freeway. It is most noticeable when I am driving on the freeway and trying to accelerate from 50-60mph. I feel a shake when I stepping on the gas at that range. Also, my gas mileage has dropped dramatically.
I also posted on Mustangworld and people have been telling me that the problem can be fixed if I simply changed the transmission fluid.
On Saturday, I brought my car into AAMCO, the transmission specialist. They told me the car has never had the transmission fluid serviced because they found this little plastic thing in the transmission fluid. Apparently, this little plastic thing is kinda like a piece of the dipstick or something like that that comes inside the transmission fluid from the original purchase of the car.
The guy recommened I need to repair the transmission. But the problem is I think I've brought my car in for servicing at the dealerships in the past. Could it be possible that at the 30K and 60K mile servicing, the dealerships skipped on the transmission fluid change? If so, and the transmission is slipping (My problem was that my car was slipping or shaking at 30-40 mph and usually at 50-60mph on the highway) is there any recourse for me against the Ford Dealerships?
So what do you recommend me to do? Do you think maybe the AAMCO guy is trying to recommend services I don't need and maybe if I just change the transmission fluid, it'll fix the problem? He said that it won't do any good to just change the fluid because the tranny needs to be repaired. I don't know if he's lying and I can solve the problem by having the fluid changed. What ways are there to tell if the transmission really needs repair? Or is the slipping feeling i get due to just old transmission fluid?
Please advice. Thanks.
P.S. The transmission guy didn't show me any pieces of metal in the transmission fluid, so will a transmission fluid change do the job? Or is there something more serious due to the performance changes that I've felt?
svtmustang88 is offline   Reply With Quote
Old 11-24-2003, 05:38 AM   #2
Danger Dude's Avatar
OK with knowing very little about the car I would guess it is 50/50 if this will actually fix the car. Typically Franchise tranny shops scare me but I did find a good one here in Greenville SC. The Mr Transmission is very good. It is quite possible the tranny fluid has never been changed. If indeed it has not ever been serviced It should not be a problem to have them do it.
Old 11-30-2003, 06:40 AM   #3
Ponycarman's Avatar
That little plastic thingy is the plug that seals the hole where the dipstick goes in. When the dipstick tube is installed at the factory it gets shoved into the pan.
When I changed my trans fluid last month I found that plug and it scared me. Not really being a Ford man I didn't know about the plug, so I assumed something fell out of the valve body.
I looked around to see if I could figure out where it went. Nada. I had to clean up and start surfing the net to find an exploded diagram of the trans. Found one, but no help. So I surfed some more and found out, on a Ford truck website, all about this plug. To verify I went to the local Ford dealer, three blocks away, and talked to the techs.
It is possible to change the trans fluid without dropping the pan, they have machines that will exchange the fluid. So the plug still being in our pan doesn't necessarily mean it's never had it's fluid changed.
Aamco wouldn't be my first choice for trans work. I do my own work.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 12-02-2003, 11:09 AM   #4
Send a message via AIM to v6stanger
I think the problem yo uare having is torque converter shudder that is common past 50k in AODE and 4r70w transmissions. I would simply change the fluid and filter (Make sure to use Mercon V and flush the torque converter and pan).
It is no big deal if the car has 60k and the fluid was still original as long as the fluid wasnt' brown in color and burnt.
v6stanger is offline   Reply With Quote
Old 12-09-2003, 05:49 PM   #5
i do not understand why people DO NOT change their tranny fluid EVERY FREAKING year... its not that expensive 30k is ok~ but every eyar is better, if the ford lot didnt change it and you asked them to and they charged you for it i would raise hell, but they probably idnt do anything other than changet eh oil, air filter and top off your fluids and send ya on your way, they only recommend it every 50k.... i wonder why.... so it will need to be really serviced and you will have to pay them out the *** to get it done.
changing automatic transmission fluid 007z28350 Pre-2005 V6 Mustang 8 08-30-2009 02:25 AM
Automatic Transmission Question? TriStateStang Pre-2005 V6 Mustang 10 01-24-2008 01:54 PM
99-04 Automatic transmission Dark02Pony 1996-2004 Mustang GT 4 11-21-2005 03:09 PM
Automatic Transmission upgrades Five_OH 1979-1995 Mustang GT 3 11-01-2004 08:12 PM
02:17 PM
