What cams have the best sound - Mustang Evolution
Old 06-01-2013, 02:54 PM   #1
greenstang41's Avatar
Not looking for performance gain just the sound
greenstang41 is offline   Reply With Quote
Old 06-01-2013, 02:56 PM   #2
MidnightBlueGT's Avatar
Why wouldnt you want the cams to perform well over a sound?
Old 06-01-2013, 02:57 PM   #3
FortyBrandon's Avatar
Get a ghost cam!
FortyBrandon is offline   Reply With Quote
Old 06-01-2013, 03:48 PM   #4
Its all opinion when it comes to sound preference. I personally think Stage 3 Comp Cams sound the best, but those aren't that good for a non-built DD car, second place for me goes to Stage 2 comp cams, which are very streetable.
Old 06-01-2013, 04:20 PM   #5
Torchredfrankie's Avatar
In the same spot want a cam for sound and some power but not to the point were I have to change my springs and all that outer stuff
Torchredfrankie is offline   Reply With Quote
Old 06-01-2013, 04:23 PM   #6
davidcseifert's Avatar
Region: Arkansas
Stay at or under .460 lift for stock springs to have some life out of them. Cheap spring upgrade, LS springs and gt retainers for proper install height, handle mild lift cams (.550) just fine.
You can get a cam reground instead of spending $400 on a new one, works just as good.
blower/new cam soon
Old 06-01-2013, 05:40 PM   #7
samuelsmith's Avatar
If you do not want to buy springs here is the cam you need to go with.
NEW SUPER SIX MOTORSPORTS Low Lift “LUMPY” cam is designed for use with stock valve springs and stock rocker arms, computer tuning required for best power, efficiency and drivability.
Duration Lift Rockers LSA
214/224 .46/.46 Stock 110
12:59 AM
