helllpppppp noww - Mustang Evolution
Old 06-02-2013, 03:00 PM   #1
andregayola's Avatar
helllpppppp noww
im trying to take my center consol out with the AC and the radio
my problem is i can come out the top snaps off were the vents are ad i removed the two torxs screws out my car is a 99
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 06-02-2013, 03:01 PM   #2
It just snaps off
Old 06-02-2013, 03:02 PM   #3
im pulling as hard as i can and its not budging the radios are conning out with it what else do i need to remove
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-02-2013, 03:05 PM   #4
Mustang81596's Avatar
You have to take off the bottom piece first (the one around your shifter). Then the top pops off. Take a screw driver and use it to pry it if you need to. Just make sure not to break the clips
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 06-02-2013, 03:07 PM   #5
Venomouz831's Avatar
Looks like he has that out already
)02 Gt, Founder of WE2G
Old 06-02-2013, 03:07 PM   #6
i did
nothing in pulling really hard and it won't budge a inch on the bottom
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-02-2013, 03:08 PM   #7
Can you get a screw driver on try to pop it out from the sides
Old 06-02-2013, 03:09 PM   #8
Originally Posted by andregayola View Post
i did
I take a screwdriver to mine and just give it a nice little twist if it won't come out for me.. Give it a shot
Old 06-02-2013, 03:10 PM   #9
i true im putting force but not even a movement just bending
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-02-2013, 03:16 PM   #10
I take it you already tried pulling from the bottom? And watch out, don't warp it or snap it.. They're pretty hefty to replace
Old 06-02-2013, 03:18 PM   #11
I tried i need too i need help any one with my year ever take it off i need too lol
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-02-2013, 03:45 PM   #12
sam62893's Avatar
I can take mine off in a couple of seconds is needed. Just get a flathead and stick it in those parts that don't want to come off. Just push it off with the flathead.
Old 06-02-2013, 03:51 PM   #13
hepler02's Avatar
Might be bending if its a billion degrees in ur car..heat tends to make plastics and things softer which might be cause the bending
hepler02 is offline   Reply With Quote
Old 06-02-2013, 04:00 PM   #14
yea it's really hot but still n does ur radios come off as well?
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-02-2013, 04:01 PM   #15
samuelsmith's Avatar
Great carbon fiber. Mine just slid off one day and got lost.
Old 06-02-2013, 04:03 PM   #16
sam62893's Avatar
No, the radio is bolted onto the dash. Ill take mine off right now and take pics
Old 06-02-2013, 04:10 PM   #17
hepler02's Avatar
I honestly never had to removel my radio bezel so far..did u stick a screw driver into the bottom corner left or right
Old 06-02-2013, 04:15 PM   #18
I'm pretty sure it shouldn't even if its stock
Old 06-02-2013, 07:22 PM   #19
---------- Post added at 07:22 PM ---------- Previous post was at 07:21 PM ----------
pictures??
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-02-2013, 07:28 PM   #20
sam62893's Avatar
pictures??
Sorry, Netflix has got me distracted here's picture 1, flathead
Old 06-02-2013, 07:29 PM   #21
okay i got that
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-02-2013, 07:33 PM   #22
sam62893's Avatar
Four clips total holding it in. The two at the bottom are parallel with the traction control, fog light, defroster, etc buttons
ID:	111839   Click image for larger version
ID:	111841   Click image for larger version
ID:	111843   Click image for larger version
Old 06-02-2013, 07:34 PM   #23
sam62893's Avatar
And the radio is being held by those two outside bolts
Old 06-02-2013, 07:38 PM   #24
sam62893's Avatar
Or in your case it would be where the CD player is at
Old 06-02-2013, 08:24 PM   #25
yea but yours is the newer one mine looks dofffrent an has different mounts
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-02-2013, 08:48 PM   #26
sam62893's Avatar
Should be the same. Did you try to get the flathead and stick it where the CD player is and pry it out?
Old 06-02-2013, 08:49 PM   #27
i tried i ended up just Puting it back and leaving it for tommorow when i install my springs
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
07:07 AM
