Can someone help me ? - Mustang Evolution
Old 06-03-2013, 08:30 PM   #1
Toolbox20's Avatar
So I have a 98 mustang v6 5 speed .
And I have a bit of a issue , have no idea what to do about it .
I was driving up the road , at night , and I had the lights on , an then I get on the gas a little , an my headlights and tail lights went out , all lights went out , then underneath my stereo , there was a beeping noise .
Now my headlights will not turn on , nor the tail lights , nor the interior lights .
When I press the brake they light up , and my turn signals light up .
But when I turn on all the lights , I get nothing .
Any help is appreciated .
Toolbox20 is offline   Reply With Quote
Old 06-03-2013, 08:45 PM   #2
Ju5tAsix's Avatar
First thing to check are the fuses.
Ju5tAsix is offline   Reply With Quote
Old 06-04-2013, 04:56 PM   #3
sam62893's Avatar
Yep, fuses first. That would be your best bet. But you might have fried your switch as well. Check both fuse pales. One under your dash and one in your engine bay.
Old 06-04-2013, 10:28 PM   #4
Toolbox20's Avatar
Fuses are good .
Old 06-04-2013, 10:30 PM   #5
sam62893's Avatar
Originally Posted by Toolbox20 View Post
Fuses are good .
Seems like the switch went out. You probably fried the cable or something because all those lights are controlled by that one switch. You're going to have to take the switch out and trace the wire
Old 06-05-2013, 12:37 AM   #6
Xaperez100's Avatar
Before replacing the switch go under the hood and check out I think it is a 30amp fuse or 20 I don't remember. This happens to my friend. And that was all it was.
Xaperez100 is offline   Reply With Quote
Old 06-05-2013, 06:08 AM   #7
sam62893's Avatar
The lights still work though, when he presses on the break.
Op, do your ambers turn on when you pull the headlight switch out? And what about turn signals?
Old 06-05-2013, 06:30 AM   #8
Xaperez100's Avatar
Yeah I know it's weird. When you break they still come on. Turn on your hazards and they all light up.. It has to do with the cluster gauge lights weird I know. But that's all it was was a fuse. Same exact thing happened to my friend. But if it isn't a fuse then idk what it would be.
Old 06-05-2013, 06:45 AM   #9
The brake lights are on a separate circuit generally. My guess is it's the switch or a fuse. I have had both a fuse do this and on another car it was the switch.
SpaceFish is offline   Reply With Quote
Old 06-05-2013, 06:52 AM   #10
sam62893's Avatar
Yep, exactly. Hazards need to work so they're more protected
Old 06-05-2013, 08:14 AM   #11
Toolbox20's Avatar
My hazards work , my turn signals work , when I press the brake the brake lights light up .
Old 06-05-2013, 09:06 AM   #12
sam62893's Avatar
Then there's something wrong with your switch or wires then. Take the gauge cluster bezel out and take a look
Old 06-05-2013, 10:38 AM   #13
Xaperez100's Avatar
Check under the hood fuses first. Easy first harder later. Just might as well check all the fuses under the hood as well.
Old 06-05-2013, 11:29 AM   #14
Toolbox20's Avatar
All fuses are good .
Today I turned the car on , an went to turn on the lights , an they all came on .
Old 06-05-2013, 11:40 AM   #15
sam62893's Avatar
Must have been a bad connection. Take a look at the switch just in case. It might happen again
Old 06-06-2013, 05:19 PM   #16
Toolbox20's Avatar
Will do .
06:58 PM
