Lacking Power - Mustang Evolution
Old 06-06-2013, 11:23 AM   #1
JimmyMosqueda's Avatar
Lacking Power
My 2003 V6 lacks so much power. This is my first mustang so I don't know if its normal for these 3.8's. The catalytic converters are bad but I'm getting them replaced with cats from davico. Could that be the reason I'm lacking? What can I do to gain more power? What bolt-ons and performance parts can I add to my stock V6?
---------- Post added at 10:23 AM ---------- Previous post was at 10:23 AM ----------
My goal is to get at least 200 horses.
JimmyMosqueda is offline   Reply With Quote
Old 06-06-2013, 11:29 AM   #2
You will need full bolt ons with head work and a cam to get 200hp.
Old 06-06-2013, 11:30 AM   #3
Any recommendations as to what brands to use?
Old 06-06-2013, 12:25 PM   #4
Venomouz831's Avatar
You're gonna spend a few bucks on bolt ons for minimal gains. Go FI or get a bottle
)02 Gt, Founder of WE2G
Old 06-06-2013, 12:56 PM   #5
sam62893's Avatar
Yep, stock 3.8 are SLOWWWW and sluggish. Heck, mines slow and I have modified CAI, and dual exhaust. And some other goodies. Getting 200 horses is possible. All the stuff they're telling you here is good.
Old 06-06-2013, 01:13 PM   #6
Easiest way is just to get a bottle (nitrous).
Old 06-06-2013, 01:38 PM   #7
Nitrous would just be a money pit wouldnt it? Keep refilling bottle after bottle.
Old 06-06-2013, 01:59 PM   #8
Its not that expensive. Its usually around $4/lb, so a 10 pound bottle will be $40 to fill approximately... And you don't run it all the time. You only use it through certain RPMs at WOT when racing, you absolutely do not run it on the street.
Old 06-06-2013, 02:02 PM   #9
andregayola's Avatar
sounds good and do y need internals?
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 06-06-2013, 02:03 PM   #10
Nitros kit won't be more than 500 bucks. Compared to bolt ons, cams and heads 3k. Or turbo or blower 3-4k
Old 06-06-2013, 02:10 PM   #11
davidcseifert's Avatar
Region: Arkansas
No, my buddy sprays a 125 shot on his HCI motor and the motor doesn't give a *****
blower/new cam soon
Old 06-06-2013, 02:17 PM   #12
stock is 193hp at the flywheel, so 200 is easy (at flywheel) but as far as rear wheels yup not going to be cheap or easy.
I would keep it simple and do gears, intake, under drive pulley, alum drive shaft and such dont spend a ton of money on the motor. You will keep wanting more and more.
Old 06-06-2013, 02:25 PM   #13
Might as well get a motor swap. Lol.
Old 06-06-2013, 02:34 PM   #14
1slosix's Avatar
Pretty much...hate to say it but if you want power unless you're ready to drop some coin on your car I'd just look for a GT.
carving corners like a boss
Old 06-07-2013, 02:00 AM   #15
Region: Arkansas
Depends, you can find deals on used FI setups normally, just have to know where to look
blower/new cam soon
Old 06-07-2013, 02:04 PM   #16
samuelsmith's Avatar
Put some blue devil in the engine. It is for internal gasket problems, but it improves compression.
Old 06-07-2013, 02:55 PM   #17
Thanks for the advice guys.
02:27 PM
