Gauge cluster problems - Mustang Evolution
Old 06-06-2013, 04:37 PM   #1
2000v6stang's Avatar
Region: Iowa
I got a white face gauge cluster from a mustang that was ether a gt or cobra because it goes to 150 mph I was wondering if it should work in a v6. I put it in and everything plugged in and it lit up but my car wouldn't turn over. I put the old one in and it started. What is going on?
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is online now   Reply With Quote
Old 06-06-2013, 05:53 PM   #2
1slosix's Avatar
the security system would need to be swapped between the clusters...along with recalibrating your car to handle the new cluster.
carving corners like a boss
Old 06-07-2013, 02:07 PM   #3
samuelsmith's Avatar
P.A.P.S. is wired to the cluster. The car thinks it is being stolen unless you go to the dealership and get it programmed in. Then your speedometer will be off. Example: It will say you are doing 50 and you are doing 45.
01:57 AM
