Darn intake bolts are impossible to find! - Mustang Evolution
Old 11-24-2003, 10:21 AM   #1
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
Well, now I can't seem to find those stupid intake bolts!
Got the 1/2" phenolic and made a spacer but now I can't find the bolts for it, so I'll be putting her back together sans spacer and keep my eyes out for some bolts for it. At least now I know the size I need:
94-98 (8mm x 1.25 pitch)
4 of them at 140 mm
2 of them at 115 mm
(stock is 130 and 105 so add 10 mm)
If anyone knows where to find these I'd be most appreciative.
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 11-24-2003, 10:32 AM   #2
Danger Dude's Avatar
Look for studs not bolts. I would go to a machine shop supplier or a tooling company
Old 01-13-2004, 10:26 PM   #3
Send a message via Yahoo to 98GreenStallion
Could someone stick this? I keep forgeting, and im going to need it this week!
http://images.cardomain.com/member_i.../402003_35.jpg
Mods: BV heads, cut and weld upper, fully ported lower, 216/225 cam, 1.73 RR's, 60mm TB, 19# injectors, new timing set, 25% UDP, CAI, SCT chip, PCV delete, EGR delete, MAC LT headers, O/R H-pipe, durablack cat-back...
www.rpm-mustangs.com
RDmotorsport
New dyno
193.8rwhp/238.9 rwtq
98GreenStallion is offline   Reply With Quote
Old 01-13-2004, 10:48 PM   #4
Dom
Dom's Avatar
Send a message via AIM to Dom
Corey, guide him!
Old 01-14-2004, 09:23 AM   #5
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
There are 6 studs on the upper intake.
Remove the 2 on each ends of the upper intake, then remove the four in the center.
Then you have to remove the 2 bolts to the EGR sensor those can be kinda a pill becuase of how they are angled.
Then remove vacuum hoses, and wires.
Then you should remove the intake and TB together.
Rellik is offline   Reply With Quote
Old 01-14-2004, 04:53 PM   #6
Dom
Dom's Avatar
That works too.
Old 01-14-2004, 04:58 PM   #7
Try here to find the bolts...
http://www.boltdepot.com/product.aspx?cc=20&cs=77&cm=19&cd=1243
Old 01-24-2004, 08:48 PM   #8
ugg those are 6mm by 1.0 pitch? Will they work?
Also a few tech Qs,
1. with a ft/pound torque wrench, what should I torque the intake bolt too?
2. where is this "hidden vaccum tube"? Is it visible without taking anything off?
Thats all for now...
RDmotorsport
New dyno
Old 01-24-2004, 11:11 PM   #9
Rick0636's Avatar
You shouldnt' even attempt to take that engine apart without a Haynes, Chilton or some kind of manual to give you some specs to go by.
Old 01-25-2004, 09:11 AM   #10
Thats true, im going to pick one of those up today or tomorrow...
RDmotorsport
New dyno
Old 01-28-2004, 07:08 AM   #11
So these bolts the Rellik suggested will work?? I found the 8mm by 1.25 pitch, but are these bolts the correct strength and all??
Thanks!
RDmotorsport
New dyno
Stage 8 bolts, but no bracket bolts? CreationNation 1979-1995 Mustang GT 1 04-13-2009 11:00 AM
Women Are Impossible Ken The Bar 37 01-10-2007 02:26 AM
Where to find these Bolts at? drummerstang98 The Bar 5 08-18-2004 11:14 AM
darn bikers 1997grnstang The Bar 1 05-16-2004 09:49 PM
1997 3.8 Intake Bolts Black95GT Mustang Parts for Sale and Wanted 5 03-12-2004 06:21 PM
04:28 AM
