8.8 rear end, tlok, and 3.73 gears - Mustang Evolution
Old 06-08-2013, 09:27 PM   #1
Sluder4's Avatar
So I want to upgrade my rear end to a 8.8 with soem 3.73 gears and a tlok.
On CL I foudn a guy that wants to sell his tlok and 3.73 gears out of his 02GT for 100 dollars. Which is cheap as crap compared to anywhere ive looked online.
So the question is if I pick a 8.8 rear end out of a junk yard would it already come with 3.73 gears and a tlok already? Should I go ahead and buy his tlok and 3.73s or just go to a junk yard and get one there?
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 06-08-2013, 09:41 PM   #2
94BlackMamba's Avatar
I think an 8.8 should already have a limited slip, but it could be pretty worn out. It more than likely won't have 3.73 gears, unless the rest of the car seems like it's had alot of performance work done to it, then there is a chance, but still not bery likely.
94BlackMamba is offline   Reply With Quote
Old 06-08-2013, 09:45 PM   #3
Sluder4's Avatar
So I should go ahead and buy these? They have 60k miles on them (so he says) but I should be able to put an 8.8 easily shouldn't I?
Old 06-09-2013, 09:04 AM   #4
fastmustangs1's Avatar
Install new bearings and gears and you'll b set dude.
fastmustangs1 is offline   Reply With Quote
Old 06-09-2013, 01:01 PM   #5
Sluder4's Avatar
Would that solve my issue with wanting to eventually after a few years install either a turbo or supercharger down the road? I heard that's why you need a 8.8 cause the stock v6 rear end cant handle that much torque.
If that isnt right please correct me im not mechanically inclined lol
Old 06-09-2013, 04:01 PM   #6
Mustang81596's Avatar
Lol you got it. The 7.5 can only handle up to 250(?) and that's pushing it I believe.
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 06-09-2013, 04:07 PM   #7
Sluder4's Avatar
Guess ill be headed to the junk yard to pull one. Im gunna go searching tomorrow and get some prices. Hopefully ill find a nice pristine GT with a Tlok, 8.8 and 3.73 gears But that's in a perfect world lol.
Old 06-09-2013, 05:39 PM   #8
Lol I just found one on Craigslist yesterday with the exact thing! I emailed and he said $500 though :/
Old 06-09-2013, 06:06 PM   #9
Crowned1's Avatar
not to burst your bubble but I'd take a look at the differental and the axles before I go for it. that sounds way to good to be true.
Crowned1 is offline   Reply With Quote
Old 06-09-2013, 08:27 PM   #10
Sluder4's Avatar
its only for the tlok and gears not the axle or anything else
Old 06-09-2013, 08:30 PM   #11
Used gears are worth $25 at most. If the tlok needs a rebuild are you really saving any money?
Old 06-09-2013, 09:08 PM   #12
Sluder4's Avatar
Really? Ill have to look at them he said it was a swap to a 4.10 set. But idk...
Old 06-09-2013, 09:11 PM   #13
1lowGT's Avatar
I wouldn't trust anyone with used parts like gears. I'd get new ones imo
Old 06-09-2013, 11:13 PM   #14
Siendly22's Avatar
+100
Siendly22 is offline   Reply With Quote
Old 06-10-2013, 12:52 AM   #15
davidcseifert's Avatar
Region: Arkansas
I had used gears in my old 7.5" axle did just fine no noise or anything, just make sure they come with a good wear pattern and find an installer that knows how to do his job lol
blower/new cam soon
Old 06-10-2013, 06:45 AM   #16
Sluder4's Avatar
Yeah ill probably pick them up. I've got a guy that does all the work in m town and he's in a band with my dad so it should be a cheap install for me and he will do a good job I'm sure! Lol
07:22 PM
