2000 v6 motor swap - Mustang Evolution
Old 06-08-2013, 10:31 PM   #1
2000 v6 motor swap
I blew the motor on my 2000 v6. And i am just wondering if anyone knows a good how to manual or site as I honestly feel imititated looking at it. I dont want to upgrade to a v8 just straight v6 for v6 swap. Thank you any help is appreciated
skobe is offline   Reply With Quote
Old 06-08-2013, 10:53 PM   #2
sam62893's Avatar
If you don't have the experience I wouldn't recommend you doing the swap yourself. It's pretty straight forward though. Disconnect all the harnesses from the engine, take hood off, radiator, unbolt the exhaust, motor mounts, unbolt tranny, jack car up from the front, get a cherry picker and pic that thing out of there and put in the new one
Old 06-09-2013, 03:29 AM   #3
lemons95's Avatar
Try and find a 4.2L engine. They used them in f150's and e150's.
Use your heads and intake on it though.
Old 06-09-2013, 12:49 PM   #4
davidcseifert's Avatar
Region: Arkansas
He can leave the 4.2's heads, just have to change intakes, saves $100 in head gaskets if you know it ran
blower/new cam soon
Old 06-09-2013, 02:11 PM   #5
lemons95's Avatar
depending on the miles, I think I would change the gaskets, maybe the bearings also.
Old 06-17-2013, 01:19 AM   #6
Biggest problem I'm having right now it's trying to determine if I need an internally or externally balenced motor, or does it even matter if I'm replacing the whole motor, I just don't want to buy the wrong one
Old 06-17-2013, 01:22 AM   #7
Region: Arkansas
Doesn't matter as long as you have a matching flywheel/flexplate and a harmonic balancer
blower/new cam soon
Old 06-17-2013, 01:44 AM   #8
Thank you!
05:03 PM
