Exhaust Manifold - Mustang Evolution
Old 06-10-2013, 05:58 PM   #1
JimmyMosqueda's Avatar
Exhaust Manifold
So a shop told me I had a cracked manifold. The same shop replaced my bad catalytic coverters. I'm no expert so I'm not sure if its supposed to have a gap between the cats and maifold. Need help! Lol
JimmyMosqueda is offline   Reply With Quote
Old 06-10-2013, 06:45 PM   #2
1slosix's Avatar
hmm i didn't think our cars had gaskets there but i see one. pretty much thought it was just a socket and ball connection
carving corners like a boss
Old 06-10-2013, 06:46 PM   #3
samuelsmith's Avatar
Its got a flange between it. Basically a big metal gasket that is pressed together.
The manifold cracks because the ac drip line drops on it. Common problem.
The 4 catalytic converters usually go out between 100,000 and 150,000 miles.
Old 06-10-2013, 06:55 PM   #4
1slosix's Avatar
i didn't think my old v6 had a gasket there and didn't think my new one had one either....just went out and took a pic
the "cracked manifold" could just be a crappy gasket they put in there when they installed the new converter...when the ball and socket should be enough to keep leaks from forming. could be a legit cracked manifold but the a/c drips on the passenger side...that pic is the driver side
Old 06-11-2013, 08:42 AM   #5
bkh1994's Avatar
If it is cracked at the flange, would that require replacing the manifold? Because I was told that I have a crack at my flange and I wanted to fix it myself but I want to know what I need
bkh1994 is offline   Reply With Quote
Old 06-11-2013, 08:49 AM   #6
1slosix's Avatar
Could probably be welded..but like I said that gasket could just be leaking since it normally doesn't have one there. Although if it comes to repairing a manifold you may consider just saving for headers and swapping since it has to come out anyways.
Old 06-11-2013, 11:55 AM   #7
Vsixpower's Avatar
This is a post within a post about my manifold as well my problem is how to i tighten the manifold tighter at the flange, or is it suppose to move at the flange. Or what does that mean when it's able to move
Vsixpower is offline   Reply With Quote
Old 06-11-2013, 12:19 PM   #8
sam62893's Avatar
Tighten it. It should fit tight. Figure out what size the nut and bolt is and tighten them with a wrench
Old 06-11-2013, 12:29 PM   #9
Vsixpower's Avatar
I've tighten them the most that I can but there is still movement in it could that mean a broken flange in the mid pipe thanks for the help
05:03 PM
