Looking at a cam - Mustang Evolution
Old 06-11-2013, 06:42 AM   #1
Zjwatts's Avatar
Looking at a cam
I have lt headers mid pipe and flowmasters what is a good cam for our cars?
Zjwatts is offline   Reply With Quote
Old 06-13-2013, 01:45 AM   #2
ProjectTurboV6's Avatar
Lumpy cam from www.supersixmotorsports.com
ProjectTurboV6 is offline   Reply With Quote
Old 06-13-2013, 05:23 AM   #3
davidcseifert's Avatar
Region: Arkansas
With any cam, remember that stock valve springs will break with just .48 lift, they are weak
Cheap upgrade LS springs and gt retainers to give proper install height, and holds moderate lift cams well.
blower/new cam soon
Old 06-13-2013, 03:30 PM   #4
Xaperez100's Avatar
What exactly does a cam do?
Xaperez100 is offline   Reply With Quote
Old 06-14-2013, 08:01 AM   #5
A cam shaft opens and closes the intake and exhaust valves simply put. When you increase the duration or lift of a valve opening you lose idle quality and emissions quality in exchange for performance. But this is only the tip of the iceberg. Combustion chamber and intake runner shapes can multiply the advantages of an increase in cam shaft profile.
Old 06-14-2013, 08:29 AM   #6
Xaperez100's Avatar
Hmm sounds awesome lol
Is it a good investment?
If I got a can for my sixxer?
Old 06-14-2013, 09:12 AM   #7
It's a great investment! But like Dave said, depending on the cam you get you'll need better springs and rocker arms to support the lift. Then a tuner is necessary to keep your 6er running smooth, you can get a 15-25hp gain from the cam and tuner combo.
Old 06-14-2013, 09:27 AM   #8
Xaperez100's Avatar
Oh nice! Looks like I'm doing that next!
---------- Post added at 10:27 AM ---------- Previous post was at 10:27 AM ----------
Is it simple to do? Could I do it myself?
Old 06-14-2013, 09:51 AM   #9
If you've never done it before I wouldn't do it yourself. See if you can find a buddy that's done it before so he can guide you along the way. A shop would probably charge an arm and a leg to do the install for you
Old 06-14-2013, 09:54 AM   #10
Xaperez100's Avatar
I've adjusted valves before.. But not on my car..
Hmm yeah I'm sure I have a friend that's done it before.
Thanks for all the info!
Old 06-14-2013, 02:39 PM   #11
Region: Arkansas
It's not really that hard to do, once you get proper pushrods length it's straightforward assembly like a stock motor, and stock rockers are ok with a .500 lift cam for sure, some use them for more but not sure of the failing point on them
But grab a Haynes manual read up a couple times on all the necessary parts to do for swap, you can do it just take your time, I had help the first time second time I did it on my own, was pretty easy
blower/new cam soon
Old 06-14-2013, 03:25 PM   #12
Xaperez100's Avatar
Cool thanks man! Also should I just upgrade rocker arms anyways?
Old 06-14-2013, 03:50 PM   #13
Region: Arkansas
It'll cost a good bit but you can
blower/new cam soon
Old 06-14-2013, 03:50 PM   #14
Xaperez100's Avatar
Better safe than sorry!
Old 06-14-2013, 08:17 PM   #15
samuelsmith's Avatar
If you look on supersixmotorsports.com under tech it will explain how to install.
Old 06-16-2013, 12:10 AM   #16
lemons95's Avatar
they have a low lift lumpy cam, its suppose to sound the same and it says it will work with stock parts.
06:57 PM
