Metal shavings while tightening my lugs? - Mustang Evolution
Old 06-12-2013, 07:07 AM   #1
Mustang81596's Avatar
Yesterday when I was putting my front wheels back on and I was tightening it, metal shavings kept showing up as I was tightening it. Why's this happening? Is it normal?
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 06-12-2013, 08:43 AM   #2
andregayola's Avatar
to probably put the nuts in backwards
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 06-12-2013, 08:52 AM   #3
zinc_yellow's Avatar
Region: New Mexico
You probably cross threaded the bolts
zinc_yellow is offline   Reply With Quote
Old 06-12-2013, 10:22 AM   #4
Could I have put the nut on backwards...? I put my wheel on and than tightened them by hand first an they easily went on
Old 06-12-2013, 12:26 PM   #5
sam62893's Avatar
This sometimes happens because you're tightening it and the lug nuts are cheap. The wheel is shaving off the metal on the lug nut as you're tightening. If it comes out easy and tightens easy you didn't cross thread the bolts. If you did it's gone be hard to replace the bolt
Old 06-12-2013, 01:19 PM   #6
Region: New Mexico
Then they aren't cross threaded scratch that
Old 06-12-2013, 04:32 PM   #7
1slosix's Avatar
Was there any anti seize on the studs? When it hardens it flakes off like shaving when you put a lug nut back on.
carving corners like a boss
Old 06-12-2013, 04:46 PM   #8
willrad00's Avatar
Are they painted lug nuts? I got some cheap lugs and the black paint shredded right off the first time i put them on.
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 06-12-2013, 05:42 PM   #9
Wow, so I think it's cuz I put them on backwards -_- I think it was from me tightening them and having the flat side of the nut cut into the surface under it -.-
Old 06-12-2013, 05:50 PM   #10
sam62893's Avatar
Oww! Did you strip the bolts?
Old 06-12-2013, 06:01 PM   #11
Checking later tonight. I hope not
Old 06-12-2013, 06:30 PM   #12
sam62893's Avatar
If you did, and you check. You won't be able to tighten them back up you'd need a new stud maybe and lug nuts. Won't be safe safe driving like that
Old 06-12-2013, 06:37 PM   #13
Yea, I'm hoping they're good worst come to worst, you know how much new studs are?
Old 06-12-2013, 07:03 PM   #14
sam62893's Avatar
$2-5 each at autozone. The hard part is getting them out
Old 06-12-2013, 07:22 PM   #15
Than that's not too bad.. What's a good way to remove them?
Old 06-12-2013, 08:20 PM   #16
sam62893's Avatar
You'll need an impact gun first of all. I wouldn't recommend doing it yourself. It involves using a mallet to strike the old studs out. And if its the front wheels you might mess up your steering rack
Old 06-12-2013, 08:21 PM   #17
Well my dads been a mechanic for 30 years so I'm sure hell be able to do it for me lol. He's got every tool you could think of haha
Old 06-12-2013, 09:14 PM   #18
sam62893's Avatar
Oh damn! Then it'll be cheap and easy! I payed $20 just to get one replaced because I didn't have an impact
Old 06-12-2013, 09:17 PM   #19
Dang dude that sucks . We have 3 in the toolbox.. Lol. He worked on tractor trailers for 10+ years
Old 06-12-2013, 09:31 PM   #20
sam62893's Avatar
You're lucky. All I got is a standard tool set (ratchets, sockets, wrenches) my drill, and misc. tools haha
Old 06-12-2013, 09:38 PM   #21
Limitation sucks
Old 06-12-2013, 10:22 PM   #22
1slosix's Avatar
studs are a piece of cake on our cars. just tap the old ones out with a hammer...use an impact, an open lug nut as a spacer, and either a closed or open lug nut to pull the stud through. i've had to replace them a few times and it's just a lot harder then it really is...just add some motor oil to the teeth on the new stud to help it pull through.
Old 06-12-2013, 10:23 PM   #23
sam62893's Avatar
Exactly what you need to do. I could do it myself but no impact. And an immovable mustang shell in my only work area haha
Old 06-13-2013, 06:54 AM   #24
Thanks for the how-to. Forgot to check last night what was up with them so doing it today after school. I hope it's all good.
09:51 AM
