speed sensors - Mustang Evolution
Old 06-13-2013, 09:41 PM   #1
mummert_96v6's Avatar
speed sensors
Where are the speed sensors located on a 96 mustang v6?
mummert_96v6 is offline   Reply With Quote
Old 06-14-2013, 11:22 AM   #2
Herbstang's Avatar
5 sp or auto ?? look on the driver's side of the tranny extension housing
Slide under the vehicle and locate the speed sensor. On a Ford transmission, the sensor is located on the driver side of the transmission, toward the rear of the unit. The sensor is a magnetic unit that screws into the transmission and has an electrical connector plugged into it.
Remove the electrical connector. Depress the release tabs on the sides of the connector and pull the connector away from the sensor. The sensor can now be removed. Twist and loosen the sensor from the transmission with a wrench. Remove the sensor by pulling it straight out of the transmission.
Install the new speed sensor. Place the sensor into the appropriate spot on the transmission. Secure the sensor by twisting it clockwise with the wrench until the sensor cannot be twisted any more. Plug the electrical connector into the new sensor until it clicks into place.
Old 06-16-2013, 09:20 PM   #3
Mines 5spd. I was told that they are on the rear, behind the calipers
Old 06-18-2013, 07:29 AM   #4
SpeedyG's Avatar
I think your talking about the ABS
SpeedyG is offline   Reply With Quote
Old 06-18-2013, 09:38 AM   #5
Lol yea I looked at it again. So the speed sensors are on the tranny?
» Members Mustangs
Saleen
05saleen
Vevo
vevo08
Add your Mustang
12:34 AM
