oil gasket - Mustang Evolution
Old 06-14-2013, 04:29 PM   #1
PiojoA7x's Avatar
oil gasket
Do I have to unmount the transmission to change the oil gasket on my 03 v6 mustang?
PiojoA7x is offline   Reply With Quote
Old 06-14-2013, 04:51 PM   #2
sam62893's Avatar
Oil gasket? Which one? Rear main seal? Oil pan gasket?
Old 06-14-2013, 05:08 PM   #3
PiojoA7x's Avatar
For either one.
Old 06-14-2013, 05:29 PM   #4
sam62893's Avatar
For the rear main seal you'll have to remove the transmission but the oil pan no. It's going to be real hard to take it off though
Old 06-14-2013, 06:22 PM   #5
PiojoA7x's Avatar
Thanks for the info. I think my oil is leaking from the rear main seal. I'm going to save up money so I can get a new clutch as well since they have to remove the tranny.
Old 06-14-2013, 08:41 PM   #6
sam62893's Avatar
If the leak is coming from in between the engine and tranny it probably is the rear main seal. Once you get that replaced I suggest you flush your tranny fluid and change the filter as well because oil may have gone in there. I have the same problem with my 01. Seal is about $30 and they quoted me $300 to fix it. I would do it myself but I don't have a lift or transmission jack
Old 06-14-2013, 08:45 PM   #7
PiojoA7x's Avatar
My v6 Is manual transmission. Will it have a filter?
Old 06-14-2013, 08:50 PM   #8
sam62893's Avatar
I'm not entirely sure. Haven't worked much with standard.
Old 06-14-2013, 08:57 PM   #9
Tyoung68's Avatar
No filter just fluid and you dont need a transmission jack just man handle that *****!! Haha but it does make it a lot easier. Just jack the the car high enough to work under it.
Old 06-14-2013, 09:10 PM   #10
sam62893's Avatar
You want to come down and hold my transmission for me??? Hahaha you could save me $300. But yeah, jacking up the car is probably the hardest part
Old 06-17-2013, 01:06 AM   #11
PiojoA7x's Avatar
What makes the rear main seal get damaged?
Old 06-17-2013, 01:56 AM   #12
tc x 4's Avatar
They wear out over time.
08:39 AM
