Understeer - Mustang Evolution
Old 06-14-2013, 11:19 PM   #1
Surffer227's Avatar
Understeer
So I put the Gt rear sway bar in and noticed an increased amount of understeer, I was just reading up and apparently you should upgrade your front one to? I MUCH prefer oversteer rather than understeer, so my question is what year v8s have a bigger front sway bar than my stock front on my 01 v6?
Surffer227 is offline   Reply With Quote
Old 06-15-2013, 05:24 AM   #2
1slosix's Avatar
A mach one does...the gt ones are pretty much the same. Some got a slightly thicker unit but they weren't specific to any particular year.
carving corners like a boss
Old 06-15-2013, 07:04 AM   #3
fastmustangs1's Avatar
You probably have a thicker front bar which will increase ur understeer issues. Why not go with an adjustable rear bar if u want to add a bit more oversteer.
You can also try running a heavier spring rates in the rear or put on a V6 front bar.
Also you can add more negative camber and pos castor to increase a bit more steering.
fastmustangs1 is offline   Reply With Quote
Old 06-15-2013, 08:18 AM   #4
Surffer227's Avatar
What about the steeda front bar? Someone near me is selling one on Craigslist, doesn't a bigger front and smaller back decrease understeer but increase oversteer?
Old 06-15-2013, 09:52 AM   #5
It will do the opposite and increase understeer. What you would need to do is run a smaller front bar and larger rear bar if u wanted to add oversteer. You can also try adding a heavier rear spring etc.
Old 06-15-2013, 10:17 AM   #6
Surffer227's Avatar
Well I noticed a increase in understeer when I put in my rear sway bar
Old 06-15-2013, 12:52 PM   #7
You will get a bit more if ur running a soft sway bar in the rear yes. Ideally if u want to increase oversteer run a thicker larger diameter stiffer sway bar in the rear.
10:00 PM
