tranny questions - Mustang Evolution
Old 06-16-2013, 12:29 AM   #1
tranny questions
So I have an automatic 03 V6 with around 113K miles. Well while I was driving I noticed a weird noise sounded kinda like a tractor lol and I notice that center (where cup holders are) was getting warm to the touch so Idk I thought I guess tranny is getting hot. I checked the fluid and it seems fine, it's even red so I really don't know what I should expect. Oh and no it doesn't slip. Has anyone had this problem. My friends 95 v6 does it too and my old grand marquis but that had over 200K miles so I knew trouble was around the corner
Old 06-16-2013, 11:21 AM   #2
Old 06-16-2013, 11:25 AM   #3
FortyBrandon's Avatar
Bump for help
FortyBrandon is offline   Reply With Quote
Old 06-16-2013, 11:29 AM   #4
Bump
Sorry new to this forum thing
Old 06-16-2013, 11:35 AM   #5
Ubnbit's Avatar
Were u normal driving, driving up a lot of hills? What were the conditions?
Old 06-16-2013, 11:42 AM   #6
Tyoung68's Avatar
Where are your mufflers ?
Old 06-16-2013, 11:46 AM   #7
Muffler is in the back it's all stock I don't think anything might be wrong since it just recently passed emissions. And I wasn't going up hill or anything just ruleregular road. I was taking off from a red light very slowly since it was late
Old 06-16-2013, 12:02 PM   #8
sam62893's Avatar
Maybe radiator isn't cooling the tranny? Check your lines
Old 06-16-2013, 12:04 PM   #9
I'm sorry I'm an idiot at this but what do I look for or how can I check them
Old 06-16-2013, 12:18 PM   #10
sam62893's Avatar
No idiots here haha. Okay first if all, have you noticed any leaks or anything? I have little experience with transmission and cooling. But there's these two metal lines running from the radiator to the trans. You'll have to jack the car up to check them out. Just make sure they're connected. Maybe they are blocked. Someone correct me if I'm making a fool out of myself lol
Old 06-16-2013, 12:55 PM   #11
Well I visually checked them and I don't see nothing weird and nothing is leaking.
Old 06-16-2013, 01:01 PM   #12
SpeedyG's Avatar
Cracked manifold making the noise?
SpeedyG is offline   Reply With Quote
Old 06-16-2013, 07:47 PM   #13
Mustangdust's Avatar
My makes a weird noise too lol dose not get hot or slip olny when rolling with out the gas down you can here it
Mustangdust is offline   Reply With Quote
Old 06-16-2013, 07:50 PM   #14
I never put my car under a lot of pressure it stays under 2000 rpm never higher cause I'm scared but It doesn't make the noise all the time
Old 06-16-2013, 11:38 PM   #15
sam62893's Avatar
You don't have much control over the Rpms in an auto though. So that means you drive REAL slow. Do you drive up hills a lot?
Old 06-16-2013, 11:53 PM   #16
I don't drive slow just the limit I know I don't have a cobra so I don't see why act like a jerk lol. Yea I do go uphill on my way to work and the on ramps here in phoenix go kinda high. That's mostly when my old car would make that same noise but I not this one (that I know of)
Old 06-17-2013, 08:57 AM   #17
sam62893's Avatar
I'm not acting like a jerk? I'm just saying that if you keep it below 2k Rpms you're probably driving pretty slow. I don't have a cobra either just V6's maybe that's why. It's freaking hot in AZ and the hills don't help cool your tranny, they make them work harder
Old 06-17-2013, 10:31 AM   #18
Tyoung68's Avatar
Check your cats
Old 06-17-2013, 10:56 AM   #19
I meant me driving like a jerk sorry for the confusion
Originally Posted by travisb.young66 View Post
Check your cats
My dad actually said that. I'm taking it to a shop later I'll let you guys know what it was
Old 06-17-2013, 11:30 AM   #20
Tyoung68's Avatar
Just crawl under and hit them with a hammer or something itll be pretty obvious once you hear it
Old 06-17-2013, 03:21 PM   #21
Took it to a shop and said it was the catalytic converter but quoted me 700 to fix it. Due I really need it the noise doesn't bother me Ican just turn the music louder lol
Old 06-17-2013, 03:50 PM   #22
9tee7pony's Avatar
I had the cats hollowed out on my old Camaro; all it would do is turn on the check engine light every once in a while for an o2 sensor and sound funny. It never bothered me so I left it, and since my state doesn't have emissions, it didn't matter. I think you said that your state had emissions, so I would just get it fixed before you have to get it checked again.
9tee7pony is offline   Reply With Quote
Old 06-17-2013, 03:58 PM   #23
sam62893's Avatar
Nah! Take it to an exhaust shop. And if you keep driving wit a clogged cat you'll have problems in the future. Have the exhaust shop hollow or cut off your cats. Or you can find used cats on Craig's and get the old ones cut out and weld the new ones in
Old 06-18-2013, 12:32 PM   #24
Anthony8994's Avatar
also take a spray bottle of water to all of your hoses in the car if you see any air bubbles you know you have a hole in those hoses
Anthony8994 is offline   Reply With Quote
Old 06-18-2013, 12:45 PM   #25
Tyoung68's Avatar
+1 add a little dish soap its easier to see bubbles
Old 06-18-2013, 01:05 PM   #26
This hose is ripping but idk what it's for
And is this supposed to be loose. When I changed my spark plug wires it came off real easy. You can basically flick it off
Old 06-18-2013, 01:23 PM   #27
Vsixpower's Avatar
First pic I think it's part of ur radiator to relieve n e pockets I air... Second one goes connected to ur manifold vac hose that's where I put my sea-foam I would replace n e thing that may be torn or worn out ... N e one correct me if I'm wrong...
---------- Post added at 02:23 PM ---------- Previous post was at 02:19 PM ----------
The second one shouldn't be a prob it's just pushed in if u take it off n put ur finger on it it should have suction u also have a second one on the other side connected to u intake..
Vsixpower is offline   Reply With Quote
Old 06-18-2013, 01:35 PM   #28
irishn8's Avatar
So cats cause tranni noise? I doubt that, if ur worried a out it though then get high flow cats. Then at least ur doing something for the environment AND ur performance. I think i know that tranni noise ur talking about. Its like gear noise at low speeds?
Old 06-18-2013, 02:02 PM   #29
I don't think it might be the tranny anymore. The mechanic took it for a drive and going up to get the freeway you can hear a noise when your next to a wall but as soon as he let go of the gas it would stop.
Old 06-18-2013, 04:18 PM   #30
sam62893's Avatar
Is it coming from the rear of your car? Could be many things. Wheel bearing, drive shaft etc.
Old 06-18-2013, 07:50 PM   #31
Can't exactly say it's coming from the back I've heard bad wheel bearings and it doesn't sound like that
Old 06-19-2013, 01:04 AM   #32
irishn8's Avatar
Any way at all you could describe the sound better? Maybe a video so i can hear it?
09:26 PM
