Stock head unit aux port - Mustang Evolution
Old 06-17-2013, 01:35 PM   #1
JRowe79's Avatar
I have a stock 6 cd changer, is there an aux port in the back of the head unit? There is an aux button?
JRowe79 is offline   Reply With Quote
Old 06-17-2013, 01:44 PM   #2
rangerbert's Avatar
What year is your Mustang
rangerbert is offline   Reply With Quote
Old 06-17-2013, 01:51 PM   #3
JRowe79's Avatar
2004
Old 06-17-2013, 01:55 PM   #4
rangerbert's Avatar
Ok. I'm not sure about the 94-2004 model years. I have an 08 and it's located in center console under arm rest. You could try that.
Old 06-17-2013, 02:01 PM   #5
sean5.0's Avatar
It's not you are just gonna have to pull it out and check I never have I've owned two new edge models but never thought to check
sean5.0 is offline   Reply With Quote
Old 06-17-2013, 02:53 PM   #6
JRowe79's Avatar
Ok guys thanks, ill pull it out tomorrow And check behind it
Old 06-17-2013, 03:04 PM   #7
sam62893's Avatar
I honestly doubt it does. Is it the Mach head unit?
Old 06-17-2013, 03:09 PM   #8
JRowe79's Avatar
Yea it's the Mach 1 head unit
Old 06-17-2013, 03:11 PM   #9
sean5.0's Avatar
He means the Mach 360 sound system that came in the premium new edge stangs
Old 06-17-2013, 03:19 PM   #10
JRowe79's Avatar
Oh man, I think it's Mach 460 is what the tweeter says. I have a 2004 Mach 1 edition mustang.
Old 06-17-2013, 03:33 PM   #11
SpeedyG's Avatar
New edge? Aux in cars was not invented yet lol
SpeedyG is offline   Reply With Quote
Old 06-17-2013, 03:36 PM   #12
JRowe79's Avatar
In 04? I just know on the head unit it says cd/aux.
Old 06-17-2013, 04:06 PM   #13
sam62893's Avatar
You have the Mach 460 sound system, not the Mustang Mach 1. I have an 01 V6 with the Mach 460 but not the stock head unit. And I have a 97 as well but not the stock head unit. And I have an 02 without that Mach 460 sound system. Instead it comes with the stock mach system and it doesn't have aux
ID:	114489   Click image for larger version
Old 06-18-2013, 07:14 AM   #14
sean5.0's Avatar
Lol Mach 460 I said 360 I was playing Xbox at the time of that post.
Old 06-18-2013, 03:28 PM   #15
bkh1994's Avatar
That one doesn't look like mine. Does this one?
bkh1994 is offline   Reply With Quote
Old 06-18-2013, 04:12 PM   #16
sam62893's Avatar
You have the premium 6 cd changer one. Do you know if you have the Mach 460? You should have speakers opposite your side mirrors for the 460
Old 06-18-2013, 04:59 PM   #17
SpeedyG's Avatar
Just checked, there is no aux port for the our cars stock
Old 06-18-2013, 06:14 PM   #18
bkh1994's Avatar
Yeah I got speakers right there in the window beside the side mirrors. Does that mean I got mach 460?
Old 06-18-2013, 08:15 PM   #19
sam62893's Avatar
Yessir you have the better Mach 460 sound system. Congrats, you have better speakers!
Old 06-18-2013, 08:31 PM   #20
bkh1994's Avatar
Except for the blown passenger side one lol
Old 06-18-2013, 08:42 PM   #21
sam62893's Avatar
Don't make much if a difference haha my tweeters aren't even connected and it still sounds good
Old 06-18-2013, 10:23 PM   #22
JRowe79's Avatar
This is like the one Fromm car, it's a 6 cd changer and there is an cd/aux port on it, so shouldn't there be an aux port somewhere in the back of it?
Old 06-18-2013, 10:27 PM   #23
sam62893's Avatar
I don't see the aux port and I doubt it has one behind it. But you have it out you can check can't you? There's no place else an aux port can be other than the head unit
Old 06-18-2013, 10:29 PM   #24
JRowe79's Avatar
That's not mine, that's one like the one I have haha, I didn't wanna take it out unless I knew there was one back there haha
Old 06-18-2013, 10:33 PM   #25
sam62893's Avatar
It's easy to take your radio out. But thers no aux input there. Just get a new double din touchscreen!
Old 06-18-2013, 10:34 PM   #26
JRowe79's Avatar
Moneys tight right now haha:p
Old 06-18-2013, 10:36 PM   #27
sam62893's Avatar
I feel ya man. I got mine with credit. $60 a month and well worth it
Old 06-18-2013, 10:45 PM   #28
Xaperez100's Avatar
Take a picture of yours and put it up
Xaperez100 is offline   Reply With Quote
Old 06-18-2013, 11:32 PM   #29
1slosix's Avatar
there is no AUX port on any mach head unit...the cd/aux button is for the off chance you buy an aux adapter that last i checked ran over $60. it'll allow you to run an aux and use that button to put the car into DJ mode. however you're just better off buying an aftermarket headunit for cheap with and AUX port and the correct dual harness (if you have the 460).
also as stated before your car is not a mach 1 edition v6....there is no such car. someone that owned your car previously just put a mach one vinyl on the side of it. the mach sound system is an option over the years where they had i'm wanting to say 3 different packages...the standard mach, the mach 460, and the mach 1000...someone correct me if i'm wrong on that
carving corners like a boss
Old 06-18-2013, 11:39 PM   #30
SpeedyG's Avatar
Here is why the button says AUX, bcuz you can buy a add on for it to play AUX/satellite radio. Look at the compatible ford vehicles. There's your car.
http://www.oemautosound.com/pc-211-8...at-button.aspx
Old 06-19-2013, 05:56 AM   #31
JRowe79's Avatar
Ok thanks guys, and yea I seen that, I have to have an adapter to make the amp and subs work on an aftermarket radio don't I?
Old 06-19-2013, 06:01 AM   #32
SpeedyG's Avatar
You might have better luck finding out answers in the AUDIO section. Give it a try
Old 06-19-2013, 07:23 AM   #33
JRowe79's Avatar
Thanks man
Old 06-19-2013, 07:27 AM   #34
sam62893's Avatar
Sort of like an adapter. It's just a wiring harness that connects the factory harness to your aftermarket head unit. You crimp the wires on the adapter to the wires on the aftermarket unit
Old 06-19-2013, 12:07 PM   #35
RaysV6's Avatar
Send a message via Yahoo to RaysV6
In my experience in order to get the amp to work a seperate adapter needs to be purchased and u have to have wires ran from every single speaker, Because of the mach system. Ford is weird some mustangs have amps v6 or not and some dont. Its weird how for can come up with alot of different configurations.
RaysV6 is offline   Reply With Quote
04:15 PM
