Lean - Mustang Evolution
Old 06-19-2013, 09:28 AM   #1
kickerofdoom's Avatar
Lean
I got two codes one each for lean in each bank. What could it be and what can I do to fix it
Old 06-19-2013, 10:55 AM   #2
9tee7pony's Avatar
Check your air intake after the MAF, I know when I had that code it was because the coupler on my CAI was loose and letting air in after the MAF.
9tee7pony is offline   Reply With Quote
Old 06-19-2013, 02:09 PM   #3
lemons95's Avatar
I should check that on mine, does anyone know if a 4.2 stroker would run lean if I was still running the original 3.8 tune?
Old 06-19-2013, 05:31 PM   #4
sam62893's Avatar
I would think so. The 4.2 was an f-150 engine so my guess would be that there was more gas pumping through its lines. Trucks definitely need more gas haha
Old 06-20-2013, 11:41 AM   #5
davidcseifert's Avatar
Region: Arkansas
Slightly lean, the load scales would be off due to the increased displacement, but on a stock headed and cammed motor it wouldn't be enough to mess with anything really, at least not enough to trip sensors
blower/new cam soon
12:18 PM
