engine or performance problems?? - Mustang Evolution
Old 06-19-2013, 11:24 PM   #1
stang916's Avatar
Ok so I have been going to the tracks a lot ... I went in Jan when I had just a Cai tune and exhaust...I got 15.6 .....
Now I have 3.73 gears..tlok..New spark plugs n wires and I can't get under 16 flat...Wtf!!
I don't get it..its a auto
stang916 is offline   Reply With Quote
Old 06-19-2013, 11:35 PM   #2
1slosix's Avatar
how many trips have you made since those mods? how many passes? things like weather, and track prep also play a lot in times. was the tune redone for the gears and tlok? don't see the plugs and wires causing an issue...if it was bad enough to hurt your times you'd know something was wrong long before you got to a track.
carving corners like a boss
Old 06-19-2013, 11:43 PM   #3
stang916's Avatar
I have went a lot since the.upgrades ... It was retuned I even contacted Bama and they said the tune is fine...I don't know I'm so confused ..
Old 06-19-2013, 11:44 PM   #4
1slosix's Avatar
i see high 15's a lot though with those mods...yes weird you're having issues but like i said track prep and weather means a lot...also how's your tires during all these trips?
Old 06-19-2013, 11:51 PM   #5
stang916's Avatar
Same stock tires 235 16...good thread ... I lowered the psi in the back to 30-35 and 35-40 in front...
---------- Post added at 11:51 PM ---------- Previous post was at 11:50 PM ----------
A ford Taurus 3.2 stock ran a 14.5 auto 1999
Old 06-20-2013, 12:11 AM   #6
1slosix's Avatar
lowering the pressure on street tires really don't help much cause the sidewalls just don't give the same...as for the taurus it's a 3.0...they offer a SOHC and DOHC and i'd assume its the 24v which makes since at a mid to high 14. i'd find a set of 555's and toss them on some spare wheels and be good to go...see what you get
Old 06-20-2013, 12:32 AM   #7
sam62893's Avatar
Lowering pressure on street tires really helped me a lot. I dropped them down to 25 psi and got a hell of a lot better traction. With 35 psi I spun my little tire all the way down the track. 1/8th mile of course
Old 06-20-2013, 12:44 AM   #8
1slosix's Avatar
Hmm I've always had horrible luck with lowered psi on street tires. I guess in the end it just comes down to track prep, and what type of street tires they are.
Old 06-20-2013, 01:03 AM   #9
sam62893's Avatar
Probably the track. I went through the water every run as well and best I could get was 10.5 I'm heading over tomorrow and see if I can skip the water and see if that helps
Old 06-20-2013, 01:10 AM   #10
1slosix's Avatar
Yeah most tracks will let you bypass the water box. Don't feel bad best I've gotten is a 10 flat when I was stock with a great track prep. That water box just kills
Old 06-20-2013, 01:14 AM   #11
sam62893's Avatar
I'm pretty much stock except for intake and exhaust no rear seats and a really stiff chassis. But I think it's the weather that's affecting him. In January it was cold up in NorCal if I'm not mistaken. It's been hot as hell lately so that could be it
Old 06-20-2013, 07:12 AM   #12
stang916's Avatar
It's not been that hot...it cool down a lot around 8 maybe down to high 60
---------- Post added at 07:12 AM ---------- Previous post was at 07:12 AM ----------
What is 555 tires??
Old 06-20-2013, 10:29 AM   #13
Crowned1's Avatar
What is 555 tires??
nitto 555s
Crowned1 is offline   Reply With Quote
Old 06-20-2013, 11:39 AM   #14
davidcseifert's Avatar
Region: Arkansas
I thought you ran 16's before and now run mid-ish 15's with the mods? That's what you said in the other thread at least..
blower/new cam soon
Old 06-20-2013, 11:44 AM   #15
stang916's Avatar
No other way around....
---------- Post added at 11:44 AM ---------- Previous post was at 11:44 AM ----------
Originally Posted by Crowned1 View Post
nitto 555s
Whould those fit on stock 16s rim
Old 06-20-2013, 11:53 AM   #16
Crowned1's Avatar
I believe they have a size for a 16" rim. oh and I should have mentioned that they are drag radials.
Old 06-20-2013, 11:55 AM   #17
Region: Arkansas
555's are street tires and 555R's are the radials
blower/new cam soon
Old 06-20-2013, 12:20 PM   #18
sam62893's Avatar
What's the difference between street and radial tires?
Old 06-20-2013, 12:30 PM   #19
Region: Arkansas
Different compounds, the radial is a softer tire and sticker, always has less groves in the tread pattern
blower/new cam soon
Old 06-20-2013, 12:31 PM   #20
sam62893's Avatar
Oh, so radial for drag racing yet still legal to be on the road
Old 06-20-2013, 02:18 PM   #21
Crowned1's Avatar
yea the radials would be the one he wants
---------- Post added at 03:18 PM ---------- Previous post was at 03:15 PM ----------
not sure if its illegal to drive with them on the daily, it didnt used to be but you can use them on the road if you're on your way to the track. but they aren't exactly ideal for day to day driving. toss the drag radials in the trunk and put them on at the track. that would be the best thing to do.
Old 06-20-2013, 02:25 PM   #22
stang916's Avatar
But would tires really make the difference for me to go back to the low 15s
Old 06-20-2013, 02:35 PM   #23
Crowned1's Avatar
they would definitely help out of the box but it all comes down to the driver, weather conditions, and the track
Old 06-20-2013, 06:14 PM   #24
Fourloko530's Avatar
Isnt that the guy david lol
Fourloko530 is offline   Reply With Quote
Old 06-20-2013, 08:57 PM   #25
Region: Arkansas
I drag race my car on the regular 555's and cut a 1.9 60' when i had stock suspension, they'll be more than enough for him plus have a longer road life than radials, and yes loko
blower/new cam soon
Old 06-20-2013, 09:15 PM   #26
1slosix's Avatar
yes tires are everything...i cut down half a second when i went from crappy Champions to my 555's.
Old 06-20-2013, 10:06 PM   #27
stang916's Avatar
How much did it run u?? .. what less do u think I should do to get better times.. I have all those mods listed plus its lowered 2in...
Would spacers help? Till I get new tires?
Old 06-20-2013, 10:50 PM   #28
1slosix's Avatar
no spacers only add rotational mass...plus the lowering hurts you
Old 06-21-2013, 12:22 AM   #29
Region: Arkansas
What is your 60' time now?
blower/new cam soon
Old 06-21-2013, 06:07 AM   #30
stang916's Avatar
Here's a slip of one of good times...
I'm on the left
Old 06-21-2013, 06:08 AM   #31
stang916's Avatar
I'm on the left
Old 06-21-2013, 08:20 AM   #32
Region: Arkansas
That 60' shows spinning for sure lol surprised your mph is only 86, are you letting out and getting back in it?
blower/new cam soon
Old 06-21-2013, 08:29 AM   #33
stang916's Avatar
No its wot all the way down....that's why I'm confused idk what to do
Help me!!!!
Old 06-21-2013, 08:37 AM   #34
Region: Arkansas
Start with learn how to launch better and get some better tires, instead of gunning it off the line roll into the throttle a little like said before lower tire pressure, I usually run 24-25lbs at the track in street tires
blower/new cam soon
Old 06-21-2013, 06:03 PM   #35
Xaperez100's Avatar
10 seconds? In a stock v6?
Xaperez100 is offline   Reply With Quote
12:13 AM
