Best power adder for v6 mustang - Mustang Evolution
Old 06-24-2013, 10:02 AM   #1
kickerofdoom's Avatar
What the best set up for a stock mustang
Old 06-24-2013, 11:41 AM   #2
sam62893's Avatar
Are you looking to spend a fortune on your V6? Go FI if you want power. You can get a least 300 hp n/a stroking it, changing the intake etc.
Old 06-24-2013, 11:58 AM   #3
davidcseifert's Avatar
Region: Arkansas
Easy solution, pro charger kit
Better power wise, turbo kit
300bhp*
blower/new cam soon
Old 06-24-2013, 01:39 PM   #4
sam62893's Avatar
300bhp*
I usually don't rate hp to the wheels, but yeah it's better to clarify, thanks David
Old 06-24-2013, 03:26 PM   #5
JRowe79's Avatar
What would be best as a one part kit? Like throttle body and such?
JRowe79 is offline   Reply With Quote
Old 06-24-2013, 04:10 PM   #6
SpeedyG's Avatar
Throttle body dosent do anything alone unless you have alot of other mods and a decent tune
SpeedyG is offline   Reply With Quote
Old 06-24-2013, 05:02 PM   #7
samuelsmith's Avatar
You need a turbo so see little results from a bigger throttle body.
Old 06-24-2013, 05:05 PM   #8
sam62893's Avatar
Overall, best power adder is 4.2 stroker and windstar jntake swap
Old 06-24-2013, 05:18 PM   #9
JRowe79's Avatar
See that's why I was wondering, I'm new at this, and I'm trying to add horsepower slowly. I know that some things add like 10 HP here of there, but over time that little HP adds up.
---------- Post added at 07:18 PM ---------- Previous post was at 07:14 PM ----------
A lot of the stuff that I look for on American Muscle for the intake manifolds are only GT? What do you mean when you say intake swap?
Old 06-24-2013, 06:58 PM   #10
He probably means cold air intake. You can do a Windstar or 4.2(pic. below) intake. The 4.2 intake needs a Cobra R hood, but the Windstar intake will fit under your hood. Both are one of the few mods that add over 10 hp.
(edit) Windstar=7 h.p. 15 tq.
The 4.2 intake is 10 times easier than the Windstar intake.
Old 06-24-2013, 07:29 PM   #11
sam62893's Avatar
Intake swap is taking the whole intake manifold off and swapping It out with an intake manifold from a windstar van. Since you're going to be doing this yourself I'm assuming, starts slow with a cold air intake, tuner, and exhaust. Once you get more experience with cars then try out bigger things. The windstar intake a 4.2 stroker are not "direct" bolt ons. You have to do a lot of tinkering with your engine bay. And Samuel I think the windstar won't fit under the stock hood without some minor adjustments.
This is my engine bay. The aluminum looking thing is the cold air intake and the silver thing in the back next to the firewall is the intake manifold.
And this I snagged from google. It's a mustang with the windstar upper intake swapped in. The air intake is sticking out from the front as where mine is sticking out the side
Old 06-24-2013, 08:15 PM   #12
willrad00's Avatar
I]And Samuel I think the windstar won't fit under the stock hood without some minor adjustments.
All thats needed is to remove the insulation from the hood.
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 06-24-2013, 08:43 PM   #13
Kingmidas87's Avatar
Personally I think the "best" first mod would be a tuner. You can get noticeable gains from a stock car, plus retune your car for every mod after that.
Kingmidas87 is offline   Reply With Quote
Old 06-24-2013, 08:46 PM   #14
SpeedyG's Avatar
That wind star setup looks sick
Old 06-24-2013, 09:29 PM   #15
Xaperez100's Avatar
Yeah and now VAP offers a slanted throttle body space to increase fitment.
---------- Post added at 10:29 PM ---------- Previous post was at 10:28 PM ----------
Btw does anyone know where they sell the full kit? VAP doesn't anymore
Xaperez100 is offline   Reply With Quote
Old 06-24-2013, 10:05 PM   #16
The kit is easy to make , but there is a hick up.
The hard part is finding the intake space between the lower and upper manifold. By the time you buy the throttle body spacer, a person might as well go for the kit.
Any one want to dig in the archives for some old records?
Am I the only one with a 4.2 upper intake manifold?
Old 06-24-2013, 10:12 PM   #17
sam62893's Avatar
David has the windstar upper and 4.2 stroker. You now have to get your windstar kit made personally.
Old 06-24-2013, 10:19 PM   #18
Region: Arkansas
I don't like the metal 4.2 intake, it's like the factory one and holds a lot more heat than the plastic windstar ones
blower/new cam soon
Old 06-24-2013, 10:49 PM   #19
Xaperez100's Avatar
What do you mean by finding the space between the intakes?
I wanna do the swap
Old 06-24-2013, 10:51 PM   #20
Xaperez100's Avatar
Old 06-24-2013, 11:05 PM   #21
Yea, it is cool. When I did the mod. ever one was into Windstar and not the 4.2 upper. I wanted to be different.
I wanna do the swap
I speak of vap's intake spacer. This goes between the upper and lower manifolds increasing the runner length good for hp and an even more impressive torque curve. It's a pre-made durable G10 Phenolic spacer the stuff astronauts use. This is a requirement due to clearance issues so the Windstar works.
Old 06-24-2013, 11:13 PM   #22
JRowe79's Avatar
Yea I'm just starting out, I'm only 18 and using this car for college, but gonna slowly make it better. I'm just looking to by a few things here and there and mess with it on weekends. Right now I'm adding the Mach 1 spoiler and blacking out the tail lights. Alot of appearance mods. First I'm thinking cold air intake, but that new intake looks really good.
Old 06-26-2013, 04:40 AM   #23
Blovett55's Avatar
Pedal mod, I thought it was stupid before I did it, it's prob most bang for your 50 cents you can buy
Then I'd say cai first, ull get the whistle which is cool
Then you can either go tuner or exhaust next, but the other one better be third, those are the first 3 mods you really should do to any car
Blovett55 is offline   Reply With Quote
Old 06-27-2013, 11:03 PM   #24
Fourloko530's Avatar
David what's ur hp and tq
Fourloko530 is offline   Reply With Quote
Old 06-27-2013, 11:52 PM   #25
AKE
AKE's Avatar
http://youtu.be/DX5e79e3mXU
I got lucky on my mustang and it came with dual exhaust ;D and cai
AKE is offline   Reply With Quote
Old 06-27-2013, 11:54 PM   #26
AKE
AKE's Avatar
Oops not the picture I thought it was XD
---------- Post added at 01:54 AM ---------- Previous post was at 01:53 AM ----------
:0 I don't have a picture of it on the iPod
Old 06-28-2013, 12:51 AM   #27
Region: Arkansas
242/250 sae was the old numbers, not sure what it is now
blower/new cam soon
Old 06-28-2013, 06:37 AM   #28
AKE
AKE's Avatar
where or what did you get the 4.2l upper intake from?
Old 06-28-2013, 07:48 AM   #29
Region: Arkansas
Me?
Mines a windstar upper, junkyard ftw
blower/new cam soon
Old 06-28-2013, 07:59 AM   #30
AKE
AKE's Avatar
Me?
what liter windstar?
Old 06-28-2013, 08:11 AM   #31
Region: Arkansas
Lol they were 3.8's, 96-98 year model intake
blower/new cam soon
Old 06-28-2013, 08:14 AM   #32
Surffer227's Avatar
Can you gasket match the windstar intake? And is ours ported better than the windstar stock?
Surffer227 is offline   Reply With Quote
Old 06-28-2013, 08:26 AM   #33
Region: Arkansas
You can match lower to the windstar but you can't port the plastic windstar itself
Assuming you mean lower is better? No them are made from the same cast basically
blower/new cam soon
Old 06-28-2013, 09:04 AM   #34
Surffer227's Avatar
I mean our upper ported compared to the windstar, you think gasket matching the windstar would help?
Old 06-28-2013, 09:50 AM   #35
Region: Arkansas
To get it to come close you have to do a cut and weld upper which is pretty expensive
blower/new cam soon
02:14 AM
