Bad IAC - Mustang Evolution
Old 06-25-2013, 09:41 AM   #1
SpeedyG's Avatar
Bad IAC
Has anyone changed their IAC before? If so what were the symptoms you experienced prior to it failing. I'm trying to figure out why my car is cranking but not turning over, according to many forums this can be why. Thanks
SpeedyG is offline   Reply With Quote
Old 06-25-2013, 09:44 AM   #2
kickerofdoom's Avatar
I had rpm dropping and hanging
Old 06-25-2013, 09:54 AM   #3
Old 06-25-2013, 01:02 PM   #4
SpeedyG's Avatar
Did it run so low that it stalled out??
Old 06-25-2013, 01:05 PM   #5
Wife just changed her's out on the gt. Car would barely idle and would stall without your foot on the gas.
Old 06-25-2013, 01:22 PM   #6
SpeedyG's Avatar
Then that has to be my problem cuz I got those symptoms. Gonna change it out today.
Old 06-25-2013, 01:25 PM   #7
She pulled into the service area at ford. Got the new iac from parts and changed it right there. Runs so much better now.
I thought I had fixed it with a good cleaning but no such luck.
Old 06-25-2013, 07:26 PM   #8
Surffer227's Avatar
What about just the iac gasket, I kinda have those problems but not very dramatic, and there's no gasket on mine
Surffer227 is offline   Reply With Quote
Old 06-25-2013, 09:19 PM   #9
SpeedyG's Avatar
What year do you have?
Old 06-25-2013, 09:19 PM   #10
Surffer227's Avatar
It's an 01
Old 06-25-2013, 09:20 PM   #11
SpeedyG's Avatar
Well I know the type of IAC I need is only for 99-00 so idk about yours. They might be different. The ones I've seen have gaskets though
Old 06-26-2013, 07:05 PM   #12
SpeedyG's Avatar
Ok I determined it's not the IAC now I'm running out of ideas.
While cranking the engine stops in mid crank and then starts again. What could that mean? I think I'm going to post a video tomorrow for some help
Old 06-26-2013, 08:36 PM   #13
fastmustangs1's Avatar
Ya mine is starting to drop real low at idle and almost wanting to die.
fastmustangs1 is offline   Reply With Quote
Old 06-27-2013, 08:44 AM   #14
SpeedyG's Avatar
Old 06-27-2013, 09:52 PM   #15
Kingmidas87's Avatar
You said "while it's cranking". Are you meaning when you're starting it? Cuz that sounds like a starter problem. If its running crappy and it's not the IAC, check for vacuum leaks then you can also try clearing you MAF with a can of MAF cleaner. It might could be an O2 sensor but not sure.
Kingmidas87 is offline   Reply With Quote
11:29 AM
