70mm throttle body? - Mustang Evolution
Old 06-25-2013, 11:51 AM   #1
AKE
AKE's Avatar
70mm throttle body?
would a 70mm throttle body fit my 01 v6? I've found one that says that it will fit but idk it true?
AKE is offline   Reply With Quote
Old 06-25-2013, 12:56 PM   #2
ProjectTurboV6's Avatar
Yup, it'll fit. Just check to see if it comes with the gasket! Won't add too much horsepower until you add other mods (tuner, cam, better heads, ect.)
ProjectTurboV6 is offline   Reply With Quote
Old 06-25-2013, 01:58 PM   #3
AKE
AKE's Avatar
awesome it also is coming with a spacer ill probably get it cause its just such a good deal
Old 06-25-2013, 03:41 PM   #4
Sweet! They're very simple to install and add a little power with the Cold air intake attached. You'd probably have to get a 70mm cai made for GTs so it'll fit!
Old 06-25-2013, 04:32 PM   #5
if it comes with the adapter then yes it should fit, otherwise it will not without opening the intake port or the butterfly will hit. i have a bbk 70mm with a cut/weld, no adapter though since the opening on intake was ported. had it posted up but it got deleted for some new rule. also need to make sure the t/b is for 01-04, 99-00 had different t/b attachments.
Just a Six
v6procharged is offline   Reply With Quote
Old 06-25-2013, 08:31 PM   #6
AKE
AKE's Avatar
See
ID:	115683   Click image for larger version
Old 06-25-2013, 08:55 PM   #7
yah, the spacer is probably tapered. if you plan to do the upper intake as well, i have a cut/weld im getting rid along with the 70mm
Just a Six
Old 06-30-2013, 06:23 PM   #8
Ghostedmind's Avatar
you're getting rid of your cut/weld upper intake?
LCMC Member
Old 06-30-2013, 06:53 PM   #9
davidcseifert's Avatar
Region: Arkansas
Yes he is
blower/new cam soon
Old 06-30-2013, 07:39 PM   #10
hmm....for how much?
LCMC Member
Old 06-30-2013, 09:26 PM   #11
pm sent.
Just a Six
12:21 PM
