Mach 1000 stereo replacement. - Mustang Evolution
Old 06-26-2013, 07:37 PM   #1
38V6STANG's Avatar
So I want replace the stereo with a touch screen with navi that fits correct. Which so far is a kenwood. But my question is that if the sound system will be the same. Like does the wiring that I have to get and use still use the amps and mini sub speakers like they r now. Please give the info.
38V6STANG is offline   Reply With Quote
Old 06-27-2013, 10:09 AM   #2
1slosix's Avatar
if it's anything like the mach 460 then you'll need a dual harness for it. check amazon that's where i found mine.
carving corners like a boss
Old 06-27-2013, 10:44 AM   #3
38V6STANG's Avatar
It only has one connector on the stereo and the the antenna
Old 06-27-2013, 11:34 AM   #4
1slosix's Avatar
and it's the mach 1000? weird..any pics of the system
Old 06-27-2013, 01:05 PM   #5
38V6STANG's Avatar
Old 06-27-2013, 02:08 PM   #6
1slosix's Avatar
looks like a mach 360 unit...a 460 and 1000 unit say it on the front. that'd explain the one harness connection on the back. you can find the plug in at any autoparts or audio place
Old 06-27-2013, 06:42 PM   #7
38V6STANG's Avatar
Ok so all I would need to buy is the two connecting wires sets from like pep boys and the new stereo will use the amp and speakers as the stock stereo is doing now.
Old 06-27-2013, 10:05 PM   #8
1slosix's Avatar
yeah
Old 06-28-2013, 08:47 AM   #9
38V6STANG's Avatar
Very kool thanks for the help.
« Leaking | rear end »
02:54 AM
