ever since i use seafoam - Mustang Evolution
Old 06-27-2013, 01:09 PM   #1
andregayola's Avatar
so i used seafoam in my car last weekend and the mpg went down dramatically half talk in three days i havnt even driven that much or stepped on it as much before half gallon lasted a the weekdays but now not even two three days what could be the problem
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 06-27-2013, 02:06 PM   #2
1slosix's Avatar
how did you use the seafoam?
carving corners like a boss
Old 06-27-2013, 03:14 PM   #3
351stroker's Avatar
How are your intake gaskets? I used all kinds of cleaners in my first Stang and the results were horrendous. It had sat in a field for god knows how many years and when I got it, it was so gutless. I put fuel injector cleaner in it, engine restore, sea foam, and numerous other things. Nothing helped. Finally I developed a lower intake leak so I changed the gaskets, took a few hours cause when I got the intake on the bench I noticed the ports full of brown/black gunk. So I steam washed the intake. All good right? No. The lifter galley was also coated in the same junk. I didn't really think too hard at the time so I cleaned what u could and put it back together, said to myself I give it 3 months lol. Well true to that thought 3 months later the head gaskets let go pushed all the antifreeze out and cooked my engine. I should have pulled the heads for what it was worth and replaced those gaskets too. I blame it on all those additives. And the fact I bought a car on an impulse.
So I'm saying u prob have bad intake gaskets I guess.
351stroker is offline   Reply With Quote
Old 06-27-2013, 05:16 PM   #4
I put it in the brake line booster thing in the tank intake n the oil
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-27-2013, 05:20 PM   #5
Vsixpower's Avatar
Did u do an oil change after u let it run for awhile when u put the sea foam in it.
Vsixpower is offline   Reply With Quote
Old 06-27-2013, 05:21 PM   #6
maldog's Avatar
Region: Nevada
Sea Foam "$UCKS"
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 06-27-2013, 05:21 PM   #7
no im going to next week
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-27-2013, 05:24 PM   #8
1slosix's Avatar
Do the oil change sooner then later. As for putting it through the brake booster line I'm going to say you probably fouled some plugs. Adding it to fast will do that easily. Its a great product and I'll stand by it on anything I own but you have to use it carefully.
Old 06-27-2013, 05:25 PM   #9
Vsixpower's Avatar
It only sucks when it goes wrong
---------- Post added at 06:25 PM ---------- Previous post was at 06:24 PM ----------
[QUOTE="1slosix;1703418"]Do the oil change sooner then later. As for putting it through the brake booster line I'm going to say you probably fouled some plugs. Adding it to fast will do that easily. Its a great product and I'll stand by it on anything I own but you have to use it carefully.[/QUOTE
++1
Old 06-27-2013, 05:26 PM   #10
yea i try n i added the sea foam really slowly ima just change all the spark plugs n do an oil change
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-27-2013, 05:40 PM   #11
351stroker's Avatar
I found just running it in the oil helps. Never tried vacuum lines. And just in the truck in the winter. Not the car.
Old 06-27-2013, 05:44 PM   #12
irishn8's Avatar
Check engine light? Maybe u cleaned up so much crap it fouled the o2 sensor. Seafoam itself wont foul anything up, it brakes down varnish and crud. Also, as previously stated, change it sooner than later, as in now. It thins out and brakes down your oil, you should only run it for around 30min, a day at most.
Old 06-27-2013, 07:49 PM   #13
oh okay then i understand ill change it next weekend n ill kep the car away n it miked a hell of alot
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-27-2013, 08:07 PM   #14
fastmustangs1's Avatar
Id stay far away from that crap.
fastmustangs1 is offline   Reply With Quote
Old 06-27-2013, 09:16 PM   #15
i feel like i works sometimes idk mabye i did something wrong like i said ill Change the plugs n the oil n check things out if anything ill just buy another car or engine
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-27-2013, 10:04 PM   #16
1slosix's Avatar
far from a crap product. i love it and sell it on a daily basis. along with use it quite often
Old 06-27-2013, 11:00 PM   #17
i just hope nothing to major happened
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-27-2013, 11:02 PM   #18
1slosix's Avatar
nah most likely it's just your plugs...maybe an upstream o2 at worse but go for the plugs first. besides new plugs are never a bad thing
Old 06-27-2013, 11:07 PM   #19
well they havnt been changed in years so that what im going to do rxt weekend along with the oil change so motor craft oil filter n royal purple oil would do fine?
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 06-27-2013, 11:09 PM   #20
1slosix's Avatar
yea
Old 06-27-2013, 11:12 PM   #21
cool should be good
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 07-01-2013, 09:38 AM   #22
351stroker's Avatar
Maybe use a better oil filter. K&N makes a very good filter. And I'm not sure what kind of mods you run but I change my plugs every year. I also use an MSD 6A on my car so it kinda burns the plugs up lol
Old 07-01-2013, 11:58 AM   #23
Mustang81596's Avatar
Just a question.. Should I wait till I am due for an oil change before using seafoam?
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 07-01-2013, 12:35 PM   #24
v8pony's Avatar
Yes, I sea foam mine the day of or the day before an oil change, I won't run more than 50 miles with it
2002 5spd GT
Feb 2013 Mustang of the Month
Old 07-01-2013, 01:03 PM   #25
Ok. When I run it through, how long should I let my car idle for?
Old 07-01-2013, 01:50 PM   #26
i did it a good five minutes then revved it until the smoked stoped
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 07-01-2013, 09:46 PM   #27
351stroker's Avatar
I agree. I use it in everything I own that has an engine. That and Lucas fuel treatment or injector cleaner. Really seems to be the only ones that work and are noticeable.
03:38 PM
