Leaking - Mustang Evolution
Old 06-28-2013, 07:02 AM   #1
Vsixpower's Avatar
Leaking
I replaced my thermostat today n it's still leaking from the bottom of the housing n e ideas why this might be... Did I put it on wrong??
Vsixpower is offline   Reply With Quote
Old 06-28-2013, 07:33 AM   #2
check the gasket chances are its bad or not right,
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-28-2013, 07:45 AM   #3
Vsixpower's Avatar
Can a new housing replace the issue
07:35 AM
