My blown engine - Mustang Evolution
Old 06-28-2013, 06:24 PM   #1
greenstang41's Avatar
My blown engine
greenstang41 is offline   Reply With Quote
Old 06-28-2013, 06:32 PM   #2
samuelsmith's Avatar
Hate to see what happened to you're engine. Had to prove I was resilient and rebuild mine. Hope you make the best out of the worst situation.
Old 06-28-2013, 06:41 PM   #3
I wanna do a v8 swap but I keep hearing it too difficult and afterwards the car has no value
Old 06-28-2013, 06:55 PM   #4
sam62893's Avatar
The cars value is what it is in the car market. If the VIN says V6, you'll get the value of a V6 even if it has a V8, V10, or V12 engine. Unless it's something that someone wants specifically. No amount of mods will make it worth more or less. It's always: condition, miles, and "do I look cool in it". Anyways. I'm sorry to hear about your car. It would be cheaper to get a junkyard V6 and out that in there. Save the engine, rebuild it, and build it up the way you want it. Look at the bright side. You have a blank 'damaged' slate to work on.
Old 06-30-2013, 10:10 AM   #5
lemons95's Avatar
If you keep it a V6 you have to go with the 4.2, more power and it will cost the same as a 3.8.
Old 06-30-2013, 03:02 PM   #6
SpeedyG's Avatar
What's that in the pic?
SpeedyG is offline   Reply With Quote
Old 06-30-2013, 03:06 PM   #7
Vsixpower's Avatar
Looks like oil pan
Vsixpower is offline   Reply With Quote
Old 06-30-2013, 06:57 PM   #8
davidcseifert's Avatar
Region: Arkansas
Wtf did you do to throw a rod? No oil or 10000rpms?
blower/new cam soon
Old 06-30-2013, 09:27 PM   #9
sam62893's Avatar
That's what I was thinking. Revving it too much?
Old 06-30-2013, 09:44 PM   #10
Region: Arkansas
I rev my stock ***** to 6500 you better have made it past 8! Lmao
blower/new cam soon
09:30 PM
