V8 swap - Mustang Evolution
Old 06-28-2013, 06:40 PM   #1
greenstang41's Avatar
V8 swap
Would the car really loose value and could I use a different 4.6 other than a mustangs because I can't find a mustang engine at all
greenstang41 is offline   Reply With Quote
Old 06-28-2013, 06:56 PM   #2
sam62893's Avatar
I responded to the value comment in your other thread. But yes. Other ford V8 engines can fit in there as well. Hell, you can make anything fit if you shove enough money down its tailpipe
Old 06-28-2013, 07:12 PM   #3
samuelsmith's Avatar
High Performance Ford 3 8 Mustang 4 3 V6 Stroker Engine | eBay
Why don't you put this engine in . It comes with a three year warranty.
Old 06-28-2013, 07:42 PM   #4
FortyBrandon's Avatar
Sell and get a gt!
FortyBrandon is offline   Reply With Quote
Old 06-28-2013, 07:48 PM   #5
sam62893's Avatar
How much can he get from an NE with a blown engine? Might as well rebuild it
Old 06-28-2013, 09:54 PM   #6
davidcseifert's Avatar
Region: Arkansas
Never even heard of them.. They must get materials cheap or put no work into porting the heads/intake
blower/new cam soon
Old 06-29-2013, 04:18 PM   #7
I live in MS. and herd about em at the casino from a v6 Mustang enthusiast. They are a little closer to my home turf because they are out of AL.
If you got a L.S.A. machine you can buy the program that re-blueprints the heads.
Numbers:
This engine is a modified 3.8 RWD Ford Mustang Engine. This engine has been built as a Street and Strip engine and is designed be used as a daily driver, we have Bored and Stroked this 3.8 engine to 4.3 L. The Cylinder Heads have recieved a 5 angle valve job and been fitted with 1.892 Intake Valves and 1.491 Exhaust valves and performance springs. The Stroker is fitted with a .480/.480 204-216 @ .050 Camshaft which will deliver strong torque and pull to 5800 RPM's. The engine is built with the compression ratio set at 9.5 to 1 to make it pump gas friendly. 24 pound injectors are recommend for a non-nitrous natural aspirated application.
The cam is a little small.
Old 06-30-2013, 03:45 PM   #8
andregayola's Avatar
oh question can a v10 triton engine from a truck fit in there?
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 06-30-2013, 04:12 PM   #9
sam62893's Avatar
:lmao; you'd probably have to cut some things and get a huge hood and probably lift up the car
Old 06-30-2013, 05:15 PM   #10
Yupp...takes some work though. Came close to buying a fox hatch that a friend did the swap on. Sounds funky
Old 06-30-2013, 06:09 PM   #11
sam62893's Avatar
Sounds like a beast!
Old 06-30-2013, 07:11 PM   #12
what are the hp number u expect ??
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 07-01-2013, 11:49 AM   #13
what about a viper engine in our cars??
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 07-01-2013, 02:35 PM   #14
Project Pony's Avatar
Anything can be done with enough money.
[SIGPIC][/SIGPIC]
Old 07-01-2013, 04:04 PM   #15
SpeedyG's Avatar
SpeedyG is offline   Reply With Quote
Old 07-01-2013, 04:26 PM   #16
94sccoupe's Avatar
Region: West Virgina
Do this
94sccoupe is offline   Reply With Quote
Old 07-01-2013, 07:35 PM   #17
i wonder how it would perform and Handel the power with te viper engine
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 07-01-2013, 07:51 PM   #18
Blovett55's Avatar
Talking about different motors to put in our mustangs, this picture comes to mind
Lol
You think ricers would get off your back if this was sticking out
Blovett55 is offline   Reply With Quote
Old 07-01-2013, 09:56 PM   #19
SpeedyG's Avatar
Lol
Holy ****!!!
Old 07-02-2013, 12:37 AM   #20
haha wow lol but come on guys im serious about a v10 to be different what hp and tq can i expect and whitch v10 should i use a viper or a ford superduty v10
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
06:23 AM
