High idle - Mustang Evolution
Old 06-28-2013, 08:08 PM   #1
PRoss.20's Avatar
Region: Arkansas
High idle
So I recently installed a BBK 65mm throttle body on my 2004 3.9L v6 mustang. Since then when I start the car it will idle at 1500-2000 rpm for a good 5 or so minutes before dropping to the 1000-1200 range which I think is still a bit high. I've adjusted the idle control screw far enough out to where the throttle body doesn't even touch it when it is fully closed anymore and it still is idling high. I have a tuner and have tuned the car and it now idles fine when driving or in neutral I just can't get the idle when I'm in park to come down!
Other mods are a BBK cold air intake
Flow master American thunder exhaust
New spark plugs, spark plug wires, and coil pack
I think that's all but it's hard to remember sometimes what all I've done
PRoss.20 is offline   Reply With Quote
Old 06-28-2013, 09:57 PM   #2
1slosix's Avatar
hmm still sounds like it's not adjusted...call bbk and see if they've had this issue before.
carving corners like a boss
Old 06-30-2013, 09:28 AM   #3
SpeedyG's Avatar
Take a look at the IAC, might need cleaning.
SpeedyG is offline   Reply With Quote
11:38 PM
