Window Trim - Mustang Evolution
Old 06-28-2013, 10:48 PM   #1
02_Mustang's Avatar
Window Trim
Hey bad news for my mustang. Hail.
I was lucky and only got a few dents on my roof, but the worse spot was the trim under the window on the passenger side.
Anyone know if it just a pop out and then go to a junkyard and find a replacement and pop in, or more difficult than that?
Thank you in advance
02_Mustang is offline   Reply With Quote
Old 06-28-2013, 11:10 PM   #2
samuelsmith's Avatar
You pop em off with a flat head screwdriver. The window trim is hallow so you can probably use priers and something protective on the outside (ex.towel).
Old 06-28-2013, 11:17 PM   #3
02_Mustang's Avatar
Thank you. Ill try tomorrow but hopefully they dont just shatter.
Old 06-28-2013, 11:26 PM   #4
Use the screwdriver near the door, wedge it, not near the window. Use a towel so you do not scrape the paint.
Old 06-29-2013, 01:15 AM   #5
sam62893's Avatar
Yep, took the weather stripping off all the time when I used to lock my keys in the car on an almost daily basis. Make sure you get a good undamaged one. It should be hard to take off, if you can take it off no problems then look for a better one
« RIMS | Cleaning »
03:54 AM
