v6 stang - Mustang Evolution
Old 06-30-2013, 10:32 PM   #1
daniel95's Avatar
v6 stang
If I put true dual exhuast in my v6 would I ha e to put new o2 sensors
daniel95 is offline   Reply With Quote
Old 06-30-2013, 10:33 PM   #2
sam62893's Avatar
Not unless you want to
Old 06-30-2013, 11:09 PM   #3
daniel95's Avatar
Since its a true dual will I have to have 1 o2 sensor or 2 of them?
Old 06-30-2013, 11:13 PM   #4
1slosix's Avatar
you currently have 4 on your car...you will be keeping all 4 unless you remove the two downstreams. if you decide to do that remember you will need to have a tune to kill the code and it will not pass a visual inspection. IMO just leave your o2's alone and worry about the exhaust. are you leaving the cats? if so then the shop doing the exhaust will just cut off the y pipe after the cats and welding up a dual setup. your o2's are never even come close to being bothered in that case.
carving corners like a boss
Old 06-30-2013, 11:26 PM   #5
daniel95's Avatar
The kit am getting cones with two cats. Its on anericanmuscle.com its the pype true dual catted exhaust
Old 06-30-2013, 11:29 PM   #6
1slosix's Avatar
ah so you're going for a one in two out style. well won't be as loud as a true dual exhaust but will sound much better then stock. you'll be using all your o2's then
Old 06-30-2013, 11:30 PM   #7
sam62893's Avatar
I have it and I still have the o2 sensors
Old 07-01-2013, 12:42 AM   #8
lemons95's Avatar
That kit doesn't even touch the o2 sensors. I don't think it has cats either, as those are further up by the headers.
The kit will sound better, but it's not real dual exhaust.
Old 07-01-2013, 12:47 AM   #9
sam62893's Avatar
It's an h-pipe I believe. Not to sure though. How is it not a real dual exhaust? I have hi-flo cats on mine and all o2 sensors on
Old 07-01-2013, 05:57 AM   #10
1slosix's Avatar
AM's v6 exhausts are y piped duals unless they now sell a true dual exhaust. If they do someone link it to me because I'd love to see what they did for a mid pipe replacement. What he means by not a real dual exhaust is the whole one in two out design. Gives the looks of a dual setup but doesn't give the same sound output as a true dual exhaust..which is two completely different pipes from the headers/manifolds back.
Old 07-01-2013, 01:37 PM   #11
greenstang41's Avatar
http://www.americanmuscle.com/9904-m...k-exhaust.html
greenstang41 is offline   Reply With Quote
Old 07-01-2013, 02:41 PM   #12
lemons95's Avatar
well some of those have x-pipes, and some just connect to the Y-pipe.
Old 07-01-2013, 04:27 PM   #13
sam62893's Avatar
Soooo... This isn't dual exhaust?
ID:	116341   Click image for larger version
ID:	116343   Click image for larger version
Old 07-01-2013, 08:11 PM   #14
lemons95's Avatar
the 2nd picture looks like and X-pipe. So that's dual exhaust. When it just bolts up to the stock Y-pipe that's when its kinda weird.
Old 07-01-2013, 08:15 PM   #15
sam62893's Avatar
Yeah it's an x-pipe. What I'm getting at here is that it is a real v6 dual exhaust, because its my exhaust and it sounds pretty good so I definitely recommend op to get the real dual exhaust instead of the one that bolts on to the y-pipe lol. And op also get headers while you're there. I have BBK headers and the pull pypes x-pipe dual exhaust and I get compliments on the sound. Had a nice low growl to it but its not that loud
Old 07-01-2013, 09:19 PM   #16
How loud is it compared to stock?
03Pony is offline   Reply With Quote
Old 07-02-2013, 06:51 AM   #17
sam62893's Avatar
At least three times as loud I can tell you that. It's quiet at idle, but once you hit 3k Rpms she screams like a beast
Old 07-02-2013, 08:54 PM   #18
1slosix's Avatar
my setup is a mac prochamber and borla stingers...kinda a pricey setup but god do i love it. sadly i still have my cats on, but that'll be taken care of soon. i always reccomend btw if you can buy used and save yourself some cash.
12:44 AM
