Tachometer problem - Mustang Evolution
Old 07-02-2013, 04:53 PM   #1
Tachometer problem
My tachometer, or rpm gauge however you wanna call it, sits at zero all the time but if I knock on the plastic in front of it jumps up to the correct, or atleast I'm assuming correct, rpm reading. Other times if I punch it it will spin all the way around past redline and then sit under zero and not work at all and then occasionally spin all the way back to its proper location. How do I fix this and why does it do this?
iLandon is offline   Reply With Quote
Old 07-02-2013, 06:20 PM   #2
SpeedyG's Avatar
I believe you have connected it to the wrong wires. Recheck your circuits
SpeedyG is offline   Reply With Quote
Old 07-02-2013, 06:31 PM   #3
I've never touched the wires. It's stock gauges and wiring
Old 07-02-2013, 07:02 PM   #4
Blovett55's Avatar
Just take dash out and look, my girlfriends dodge neon had the problem with her speedo, same thing, hit it and come back, occasionally
Took apart, for first time, wires wer loose
And our new edge, not sure bout sn, but ours have problems under the dash, ever been driving and the digital odometer go out, hit it comes back on, ford some how messed up under the dash, just get under there and look, or if you don't want to, by an aftermarket tach with shift indicator, since I'm presuming urs is manual is y you care
Blovett55 is offline   Reply With Quote
Old 07-02-2013, 07:04 PM   #5
No. It's auto. Just don't like stuff broke in it. Ill have to check I guess. Can I just solder the wire on?
Old 07-02-2013, 07:07 PM   #6
Blovett55's Avatar
Understandable
And if the wires broke or even not, yes you can solder it, if its not a plug in one, idk, never had to open mine up on mustang, neon was solder
Old 07-02-2013, 07:11 PM   #7
sam62893's Avatar
Just take out the gauge cluster. Take off the bezel first. Two screws on top then it snaps off. Then the instrument cluster is by itself. Take of those screws on the cluster itself and it'll come out Nd it has two harnesses attached to it unplug and plug back in make sure they're not loose. Don't take the whole dash out. It's not that big of a deal trust me haha
ID:	116494   Click image for larger version
Old 07-02-2013, 07:16 PM   #8
Blovett55's Avatar
Yeah figured someone has just I haven't had any problems with either of mine
09:47 AM
