An easy mod - Mustang Evolution
Old 07-03-2013, 11:38 AM   #1
ProjectTurboV6's Avatar
An easy mod
If you want a little extra pep for cheap, an old school trick that I've used will help. Buy metal head gaskets (n/a setups only) and replace your old one with these. After install, warm your engine all the way up then shut it off to cool. Once its cool re torque the head bolts again. Regular gaskets are .04" thick while the metal ones are .02", raising your compression slightly.
ProjectTurboV6 is offline   Reply With Quote
Old 07-03-2013, 11:59 AM   #2
ForsakenProto's Avatar
Why not spend the money you would spend on this, on something that would actually be noticeable?
ForsakenProto is offline   Reply With Quote
Old 07-03-2013, 01:21 PM   #3
I don't even know what to say....
Old 07-03-2013, 01:34 PM   #4
Because I already said it? Lol
Old 07-03-2013, 01:35 PM   #5
McNassty's Avatar
Lol, you silly V6 guys
McNassty is offline   Reply With Quote
Old 07-03-2013, 01:50 PM   #6
1slosix's Avatar
Don't put us all in the same boat.
carving corners like a boss
Old 07-03-2013, 03:52 PM   #7
It's fast, cheap, and easy. Plus, its better than getting your heads milled so you can just do a p/p like I did.
Old 07-03-2013, 03:53 PM   #8
McNassty's Avatar
Lol sorry
Old 07-03-2013, 04:27 PM   #9
If you consider that fast, cheap and easy, i hate to see what you consider slow, expensive and hard. There's no way im doing that kinda work just to swap out head gaskets for a "performance" gain
Old 07-03-2013, 05:00 PM   #10
davidcseifert's Avatar
Region: Arkansas
You'd get ~.4 compression bump, like a 5hp difference on the wheels, even if you can do the labor on your own its $150-170 in materials and then down time.. Not worth the trouble
blower/new cam soon
Old 07-03-2013, 05:01 PM   #11
Apparently that's cheap... >_>
Old 07-03-2013, 05:09 PM   #12
Surffer227's Avatar
It's a good choice when building an engine though, just alot to do for just that
Surffer227 is offline   Reply With Quote
Old 07-03-2013, 09:48 PM   #13
sam62893's Avatar
Yeah, pretty much if you're going to go down there might as well do that. Not really a project you'd do just for the hell of it though
Old 07-06-2013, 04:56 PM   #14
That's what I'm doing right now, maybe I should've specified that.
08:01 PM
