I need help - Mustang Evolution
Old 07-03-2013, 04:29 PM   #1
Mike V.'s Avatar
I need help
My check engine light was on so I took it to the shop and they replaced a spark plug wire. After that my car seemed fine then the next day it's running like crap again, less power, and has this studder shaky feeling. When I gas it hard from a stop it just bogs and has no power at all.
Mike V. is offline   Reply With Quote
Old 07-03-2013, 04:31 PM   #2
Ubnbit's Avatar
No cel? They only replaced one wire?
Old 07-03-2013, 06:35 PM   #3
Mike V.'s Avatar
Yes the diagnostic said misfire in the 3rd cylinder so they only replaced one
Old 07-03-2013, 07:28 PM   #4
davidcseifert's Avatar
Region: Arkansas
Pull the spark plug see if the ceramic is cracked
blower/new cam soon
Old 07-04-2013, 11:35 AM   #5
SpeedyG's Avatar
I don't know it changing just 1 wire is a good idea. Should always change then together.
SpeedyG is offline   Reply With Quote
Old 07-06-2013, 03:21 PM   #6
Mike V.'s Avatar
I'm going to change them all tomorrow..hopefully that fixes the problem
Old 07-06-2013, 09:01 PM   #7
JimmyMosqueda's Avatar
Valve cover gasket leak?
JimmyMosqueda is offline   Reply With Quote
11:29 AM
