Leaking Oil - Mustang Evolution
Old 07-05-2013, 03:07 PM   #1
V6in's Avatar
Leaking Oil
So the past few months my car has been leaking oil, nothing drastic. Recently its been leaking a bit more than usual. I checked the oil filter and bolt for the oil and both are good. Anyone know if this is a big problem or a quick fix? Thanks
V6in is offline   Reply With Quote
Old 07-05-2013, 03:18 PM   #2
Venomouz831's Avatar
Well we're is leaking from? If its leaking alot then yes it is. You don't want to be left with no oil
)02 Gt, Founder of WE2G
Old 07-05-2013, 03:41 PM   #3
Leaking or burning? are you saying that oil is low but no leaks?
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 07-05-2013, 08:26 PM   #4
Billymich's Avatar
Rear main seal or oil pan gasket.
Old 07-05-2013, 08:42 PM   #5
BatmanUriah's Avatar
^This^
BatmanUriah is offline   Reply With Quote
Old 07-05-2013, 09:11 PM   #6
Billymich's Avatar
You might have forgotten to get a new crush washer when the oil was changed last, or it might have been double up on
Old 07-06-2013, 04:34 AM   #7
Jorge Hernandez's Avatar
This is happening to me and its the oil pan gasket need to replace and I tried doing but its like glued and stuff lol gonna take it to get it changed instead they have tools lol
Jorge Hernandez is offline   Reply With Quote
Old 07-06-2013, 10:02 AM   #8
Mustangdust's Avatar
It happened to me I had to replace the rear main seal and 5 hours later not oil leaking
Mustangdust is offline   Reply With Quote
07:55 PM
