Anyone else have a gas pedal that's really low? - Mustang Evolution
Old 07-07-2013, 02:57 AM   #1
skylaar10's Avatar
My gas pedal seems to be really low. If I step on the gas, it doesn't take much 'til it's already hitting the carpet, and it can't go down anymore.
I don't know if this is normal, but I can put my foot behind the gas pedal, and lift it towards me, more than 4 inches up. People keep telling me that this is normal, but every car that I go look at, I can't lift the gas pedal upwards any further, at all.
It's supposed to be lined up with the break pedal right? Everyone tells me that it's supposed to be this way, but it just doesn't seem right to me.
I'll attach some photos when I get the chance.
skylaar10 is offline   Reply With Quote
Old 07-07-2013, 02:58 AM   #2
Venomouz831's Avatar
http://www.mustangworld.com/ourpics/fcar/99pedals.htm
Here u go
)02 Gt, Founder of WE2G
Old 07-07-2013, 07:15 AM   #3
Surffer227's Avatar
Gas pedal mod, makes it feel soo much beter
Surffer227 is offline   Reply With Quote
Old 07-07-2013, 11:00 AM   #4
skylaar10's Avatar
Originally Posted by Venomouz831 View Post
I read that when you do this, you have to be careful not go punch the gas because it could snap the cable. Is that true?
Old 07-07-2013, 11:41 AM   #5
slow281
sixpac's Avatar
Region: Nebraska
Just make sure it's not super tight..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-07-2013, 12:18 PM   #6
1slosix's Avatar
You won't have any issue snapping the cable with just a one inch spacer. I've done this to all the '04s that I've had. It is a must do mod.
carving corners like a boss
Old 07-07-2013, 06:55 PM   #7
sam62893's Avatar
Doesn't a spacer do the same thing but on the other end?
Old 07-07-2013, 06:57 PM   #8
1slosix's Avatar
no because when you install a spacer they also have a cable plate that shifts the cable so it stays the same tension.
Old 07-07-2013, 07:02 PM   #9
skylaar10's Avatar
So what would be the best way to go about this? I want to make it so that I don't really have to worry that much about snapping my throttle cable if I punch the gas. I've heard it's happened to a lot of people that put spacers in. Spacers or some kind of clip, I can't remember.
Old 07-07-2013, 07:05 PM   #10
1slosix's Avatar
don't listen to those people lol...you will be 100% fine with the throttle cable mod.
Old 07-07-2013, 07:10 PM   #11
Mustangdust's Avatar
Best thing you can do and feels so much better
Mustangdust is offline   Reply With Quote
Old 07-07-2013, 07:19 PM   #12
slow281
sixpac's Avatar
Region: Nebraska
I can a spacer and the cable mod both for almost a year 'punching' it many times with not problem.. If your that worried have someone check the TB as you put your foot on the gass and make sure it's not supper tight..
2001 GT - True Blue
Old 07-07-2013, 07:27 PM   #13
Sluder4's Avatar
Whoever said they snapped it more then Likly has no idea what they're talking about.
I promise you'll love this 50 cent mod the first time you put your foot on the gas!
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 07-07-2013, 09:39 PM   #14
skylaar10's Avatar
Thanks for the info everybody! I'll be trying this sometime this week. I'll let everyone know how it goes and post a pic when it's finished.
Old 07-07-2013, 11:20 PM   #15
No won't snap.
Old 07-08-2013, 01:32 AM   #16
lemons95's Avatar
mine might be a little less than an inch, mine hit the floor before I did the mod.
I don't think it was reaching WOT before, so I would recommend this mod if your pedal is low. You'll probably feel a difference if you floor it.
Old 07-08-2013, 10:14 PM   #17
Milehigh STK's Avatar
Just did this today! haven't driven with it yet though. excited to see how it feels! Man was it a pain to install haha may be less than 2 dollars but its hell to put in!
Milehigh STK is offline   Reply With Quote
Old 07-08-2013, 10:19 PM   #18
Ghostedmind's Avatar
amen to that, i've needed to redo mine, because the tubing i put in was to flexable. Been putting it off for about 2-3 weeks now, probably going to do it tomorrow when i clean my air filter and replace my fuel filter though....
LCMC Member
Old 07-08-2013, 10:32 PM   #19
i know what you mean. I did it twice today because the first time i used a smaller nylon spacer and it would kinda turn sideways as the pedal was pushed! so went back to the hardware store got a bigger spacer and put about 8 zip ties on it! haha
Old 07-08-2013, 10:34 PM   #20
Lmao, i used some plastic tubing i already had, and put 3 zipties, i need to get the nylon spacer, or a wire crimp, but i wanted something with a LITTLE give......it just gave a little to much and never straightened back out, lol
LCMC Member
Old 07-08-2013, 10:40 PM   #21
Haha oh i see what you mean! I dont know what you could use for a little give... a spring maybe? im not sure how you would make it work but im sure there is a way
Old 07-08-2013, 11:19 PM   #22
1slosix's Avatar
i always use a 1" hard nylon spacer on hold it on with two metal clamps lol
Old 07-08-2013, 11:25 PM   #23
lemons95's Avatar
Maybe rig up a spring and two plastic bottle caps with holes in the center.
Old 07-08-2013, 11:35 PM   #24
1slosix's Avatar
lol why go through all the trouble? a solid spacer is perfect for this mod
Old 07-09-2013, 08:10 AM   #25
slow281
sixpac's Avatar
Region: Nebraska
What you use for a solid spacer?
2001 GT - True Blue
Old 07-09-2013, 08:29 AM   #26
This is what used some motorcycle gas line I had in my garage and used three zip ties and I have done it to three mustangs with no problems I used like inch to inch and half in size
Old 07-09-2013, 10:54 AM   #27
1slosix's Avatar
10 cent nylon spacer...just like in the mod guide
Old 07-09-2013, 11:03 AM   #28
slow281
sixpac's Avatar
Region: Nebraska
I couldn't find one..
2001 GT - True Blue
Old 07-09-2013, 11:03 AM   #29
brooksyx's Avatar
Been putting this mod off for a while. Think it will be my after work project today.
brooksyx is offline   Reply With Quote
Old 07-09-2013, 01:39 PM   #30
Holy **** just drive it for the first time. Incredible difference for such a little mod!
Old 07-09-2013, 11:08 PM   #31
1slosix's Avatar
now granted it really doesn't make the car any faster (track tested lol), but it sure does make the butt dyno feel better am i right.
Old 07-10-2013, 08:53 PM   #32
Oh yeah! Just feels more responsive
Old 07-10-2013, 09:26 PM   #33
sam62893's Avatar
I did it one mine. You get a more responsible throttle but it doesn't float my boat as high as everybody else. It took me a couple of minutes to relearn the pedal and now I can reach the pedal faster and that's it
Old 07-10-2013, 10:23 PM   #34
Yours may have started out better than others maybe? mine was REALLY bad so it made a pretty substantial change for me.
Old 07-10-2013, 10:25 PM   #35
sam62893's Avatar
And I also have a 65mm throttle body and spacer so that might have made a difference haha
01:53 PM
