Full rebuild - Mustang Evolution
Old 07-08-2013, 09:38 PM   #1
Region: Iowa
Full rebuild
I am redoing the whole under side of the car and going up from there , new doors fenders and everything what do you recommend for a suspension
Iowaboy13 is offline   Reply With Quote
Old 07-08-2013, 10:33 PM   #2
MidnightBlueGT's Avatar
Coilovers
Old 07-08-2013, 10:34 PM   #3
Venomouz831's Avatar
Yeap coilovers and sub frame connectors to start
)02 Gt, Founder of WE2G
Old 07-08-2013, 10:42 PM   #4
lemons95's Avatar
I don't know much about suspension(besides the fact that mine needs to be changed...) but if your doing a rebuild might want to go with a 4.2.
Old 07-09-2013, 04:17 AM   #5
Region: Iowa
Thanks , my goal is to have a motor big enough it comes out the hood
Old 07-09-2013, 05:37 AM   #6
andregayola's Avatar
then get the ford lightning motor and supercharge it then itll really pop out the hood
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 07-09-2013, 07:37 AM   #7
Region: Iowa
That's sounding good to me
Old 07-09-2013, 09:18 AM   #8
sam62893's Avatar
You won't be able to put a hood on it actually
Old 07-09-2013, 09:42 AM   #9
If you are talking about the 2nd gen lightining then they already came supercharged
Old 07-09-2013, 10:36 AM   #10
exactly and you could get a cowl hood and cut around I've seen it done well with rubber so water won't get inside it looks like a monster
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 07-09-2013, 10:43 AM   #11
brooksyx's Avatar
Agreed. If I was doing a rebuild I would try to go this route.
brooksyx is offline   Reply With Quote
Old 07-09-2013, 10:47 AM   #12
Region: Iowa
I'm awesome with fiberglass work I can build a custom hood , I'm doing a custom cowl here in a week
---------- Post added at 10:47 AM ---------- Previous post was at 10:47 AM ----------
Cowl under the wipers not the hood
Old 07-09-2013, 11:53 AM   #13
so yea u should go with lightning ull be crazy fast
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 07-09-2013, 03:03 PM   #14
lemons95's Avatar
do an m112 swap, if you have the funds it suppose to provide great low end torque. I thought it would be neat that instead of a m112 to get one of the aftermarket twinscrew superchargers. They made some for the 03/04 cobra and the V6 kit is suppose to make it use the m112 off of a 03/04 cobra so it should bolt up.
Old 07-09-2013, 03:27 PM   #15
Region: Iowa
If I do the lighting I will most likely do a shot of nos , and I talk to a guy and he told me to out a truck rear end In it cut it and use split axles
Old 07-09-2013, 03:32 PM   #16
lemons95's Avatar
just use a GT rear-end. It will be more than strong enough.
Old 07-09-2013, 10:30 PM   #17
Region: Iowa
What gears 4:15
Old 07-09-2013, 11:22 PM   #18
lemons95's Avatar
with a NA setup I'd run 4.10's, and with boost depending on how much torque i'm pushing i'd probably get some higher gears so I don't fry my tires off.
08:14 AM
