Foglight installation troubleshooting - Mustang Evolution
Old 07-10-2013, 08:19 AM   #1
TorchRed03's Avatar
Region: Nebraska
Got the wiring kit from vmp and I'm trying to do this without any electrical experience, wired the orange to the positive, black to negative, the reds to the foglights and the following blacks were grounded to bolts, ran the blue wire and spliced it to the white/black stripe wire, installed the fuse, switch is working because I see the light but I haven't gotten the foglights to turn on yet... Do I have to do anything with the box that all the wires are connected to? Instructions pictures are small and unclear, any suggestions or things to check?
2003 Mustang
intake, exhaust, tune
TorchRed03 is offline   Reply With Quote
Old 07-10-2013, 08:49 AM   #2
Did you install the relay?
Old 07-10-2013, 08:55 AM   #3
TorchRed03's Avatar
Region: Nebraska
It looks to me like it came already plugged into the wiring harness
2003 Mustang
Old 07-10-2013, 09:52 AM   #4
TorchRed03's Avatar
Region: Nebraska
Alright so I find a different bolt to ground a foglight to and I got one to turn on now to regroups the other
---------- Post added at 10:51 AM ---------- Previous post was at 10:50 AM ----------
reground*
---------- Post added at 10:52 AM ---------- Previous post was at 10:51 AM ----------
And also I'm getting ready to swap out stock fog bulbs for 35watt hids, I won't need a stronger fuse or anything right? Just using VMP's kit
2003 Mustang
Old 07-10-2013, 11:42 AM   #5
94sccoupe's Avatar
Region: West Virgina
Pics?
94sccoupe is offline   Reply With Quote
Old 07-10-2013, 12:08 PM   #6
TorchRed03's Avatar
Region: Nebraska
Here's the ballast and the rest of the hid conversion kit, and the 15 amp fuse for the little fuse box on the wiring harness, should work fine? As soon as I find a ground on the driver side for the foglight
2003 Mustang
04:28 PM
