Need suggestions for lowering springs - Mustang Evolution
Old 07-10-2013, 09:52 AM   #1
ZangStang02's Avatar
What are some springs that can get rid of the 4x4 look for a good price? Are caster camber plates needed?
ZangStang02 is offline   Reply With Quote
Old 07-10-2013, 10:05 AM   #2
Sluder4's Avatar
If you want to get cheap springs tht get rid of the 4x4 look without caster chamber plates get SR performance lowering springs of AM. They are cheap but will last and get rid of that ugly gap without having to buy caster chamber plates cause they don't drop your stang way to far down
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 07-10-2013, 11:15 AM   #3
1slosix's Avatar
i have the SR ones...works great for the money. just depends on what you want
carving corners like a boss
Old 07-10-2013, 11:15 AM   #4
Did you buy caster camber plates to go with it?
Old 07-10-2013, 07:55 PM   #5
1slosix's Avatar
no need you won't get low enough to need them
Old 07-10-2013, 08:24 PM   #6
ProudSixxer26's Avatar
I got eibach sport lines. They are pricey, but they gave me a great stance. Looks better than some GT's.
ProudSixxer26 is offline   Reply With Quote
Old 07-10-2013, 09:00 PM   #7
Can you post a pic of your car with them on
---------- Post added at 10:00 PM ---------- Previous post was at 09:59 PM ----------
Old 07-10-2013, 09:03 PM   #8
Doe_Rae_mi's Avatar
Eibach sportlines. Didnt realize the last one was blurry so I posted the unedited version
ID:	117679   Click image for larger version
ID:	117681   Click image for larger version
Old 07-10-2013, 09:05 PM   #9
Originally Posted by Doe_Rae_mi View Post
Eibach sportlines
Damn that looks very good, do you have caster cambers?
Old 07-10-2013, 09:07 PM   #10
Doe_Rae_mi's Avatar
Nahh but it wouldn't hurt to put some on lol
Old 07-10-2013, 11:19 PM   #11
Ghostedmind's Avatar
I've always heard that as long as you stay above a 2" drop you dont need the CC plates
LCMC Member
Old 07-10-2013, 11:26 PM   #12
Milehigh STK's Avatar
Are there any other upgrades needed after putting springs like the SR ones in?
Milehigh STK is offline   Reply With Quote
Old 07-10-2013, 11:51 PM   #13
1slosix's Avatar
Originally Posted by ZangStang02 View Post
Can you post a pic of your car with them on[COLOR="Silver"]
sure
Old 07-11-2013, 12:01 AM   #14
sure
it says the SR ones are only for 79-04 GT, Mach 1 and 93-98 Cobra am I mistaken?
Old 07-11-2013, 12:19 AM   #15
1slosix's Avatar
correct...however all 74-04 mustangs use the same springs (save IRS cars)..only difference is the spring rate. a GT would get more of a drop out of the SR springs then our v6's do, but it's still almost 1.5"...
Old 07-11-2013, 12:44 AM   #16
oh thats interesting. So ill be fine to go with the SR ones then?
Old 07-11-2013, 01:15 AM   #17
1slosix's Avatar
If that drop works for you then yes. Now I will say I have been considering going to a progressive spring, but it really depends what you have planned for your car.
Old 07-11-2013, 01:53 AM   #18
Crowned1's Avatar
sure
thank god I'm not the only one with non staggered bullitts lol actually looks better IMO
Crowned1 is offline   Reply With Quote
Old 07-11-2013, 01:59 AM   #19
1slosix's Avatar
Yeah I wasn't thinking when I ordered these torque thrusts and got the same all the way around...I'll have to fix that when I finish paying these off lol.
Old 07-11-2013, 02:28 AM   #20
Crowned1's Avatar
ha I like it! it looks good! 17s?
Old 07-11-2013, 03:19 AM   #21
1slosix's Avatar
Sadly yes lol
Old 07-11-2013, 11:50 AM   #22
Does getting progressive springs have a need for any other modifications?
Old 07-11-2013, 12:20 PM   #23
1slosix's Avatar
No they install just like a linear spring
Old 07-11-2013, 12:30 PM   #24
fastmustangs1's Avatar
A progressive wound spring will maintain some ride quality depends on spring rates. As the car goes into a corner the spring will stiffen increasing handling etc. As a linear spring will have relatively the same spring rate throughout the entire suspension cycle.
If u lower the ride height to much hence ( Coilovers ) you will run into excessive bump steer or toe changes and then bump travel issues with the struts and shocks. This will effect mid-corner handling and increase understeer charaterisctics. The car will also bottom out more and put the shocks on the bumpstops to much and eventually damage the internal seals on the shocks.
fastmustangs1 is offline   Reply With Quote
Old 07-11-2013, 04:13 PM   #25
Crowned1's Avatar
Sadly yes lol
haha we are in the same boat. 18s seem to be just perfect for our cars
06:24 AM
