Control arms - Mustang Evolution
Old 07-12-2013, 12:32 PM   #1
mummert_96v6's Avatar
Control arms
Does anybody have any good tips on how to get the control arm bolts out? I bent an axle and am now changing rears
mummert_96v6 is offline   Reply With Quote
Old 07-12-2013, 02:32 PM   #2
davidcseifert's Avatar
Region: Arkansas
Muscle, big socket set, and a wrench..
Spray some PB blaster an hour or so before, sometimes they rust up good and tight
blower/new cam soon
Old 07-12-2013, 03:27 PM   #3
94sccoupe's Avatar
Region: West Virgina
PB blaster is your friend
94sccoupe is offline   Reply With Quote
Old 07-12-2013, 04:09 PM   #4
Site Sponsor
Sponsor
AMWill's Avatar
+1 for PB blaster! Don't be afraid to load it up with PB, it's going to make things much easier for you. Aside from that, just use the largest ratchet you can fit in there and have at it.
Good luck!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 07-12-2013, 04:32 PM   #5
samuelsmith's Avatar
Get a adjustable wrench, put it around the rubber grommet and squeeze. Now put the socket on the nut and turn.
Old 07-12-2013, 10:24 PM   #6
Thanks for the advice guys. I ended up just cutting off the bolts. I'm gonna try and save the bushings, can't exactly afford some. Damn being 17 with a mustang isn't so much fun when it's expensive
08:09 PM
