99-04 Mustang Fog Light Setup like OEM - Mustang Evolution
Old 07-14-2013, 12:47 AM   #1
Brezzy_Lopez's Avatar
I need help with finding what's wrong with my fog lights. I set everything to almost OEM but they still don't turn on. I have power to Pin 85 of the Relay and Grounded Pin 86. The power from pin 85 is the Black/white wire from the fog light switch. Pin 30 has power from the battery and pin 87 it going to the left fog light and the right fog light Is spliced into the wire going into the left fog light and both go to ground in different spots of the Chaise. The relay clicks when I turn on the fog lights from the switch but they don't turn on. I need help, is there something I'm missing or what? Please help!
Brezzy_Lopez is offline   Reply With Quote
Old 07-14-2013, 01:02 AM   #2
1slosix's Avatar
run the grounds to the headlight ground bolts just above each headlight. i had grounding issues everywhere else when i made my harness until i used those bolts.
carving corners like a boss
Old 07-14-2013, 02:06 AM   #3
You mean the one that's near the hood latch on the passenger side and the bolt near the battery side? Because that's where I have them now
Old 07-14-2013, 11:24 AM   #4
1slosix's Avatar
No the bolts right above the headlights..both have a ground wire running to them already
Old 07-14-2013, 07:11 PM   #5
Yeah that's where I have them and I found out the problem. The wires connecting to the relay weren't connected right. They were only touching a little and they are now working properly now. Thanks for the info though man!!!!! means a lot!!!!
Old 07-15-2013, 02:17 AM   #6
Ghostedmind's Avatar
http://vmptuning.com/index.php?p=product&id=971
LCMC Member
Old 09-24-2013, 05:29 PM   #7
Milehigh STK's Avatar
Do our cars come with the hardware to install already?
Milehigh STK is offline   Reply With Quote
Old 09-24-2013, 11:59 PM   #8
1slosix's Avatar
no....even if your car came with an OEM switch like mine did the harness is still not there
Old 09-25-2013, 07:36 AM   #9
Well I have the harness ordered but I just mean nuts and bolts and such. And if not what screws will I need?
01:59 PM
