Speedometer reading - Mustang Evolution
Old 07-14-2013, 10:54 AM   #1
mummert_96v6's Avatar
Speedometer reading
I recently change my rear because I bent an axle in my old one. My old rear had 2.73 gears and my new rear has 3.27 gears, will this throw off my speedometer reading?
mummert_96v6 is offline   Reply With Quote
Old 07-14-2013, 11:09 AM   #2
sam62893's Avatar
Yessir, you're going to have to get it re calibrated if you don't want speeding tickets. I think a tune can fix it
Old 07-14-2013, 12:24 PM   #3
Mustang81596's Avatar
It's the perfect time to buy a handheld tuner. Yes it'll fix the problem
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 07-14-2013, 02:24 PM   #4
What tuner would fix the problem that's fairly cheap? I'm on a bit of a budget
Old 07-14-2013, 03:27 PM   #5
andregayola's Avatar
look around at ur local shops explain ur problem n they may be able to do a quick tune for that problem
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 07-14-2013, 04:17 PM   #6
lemons95's Avatar
I have 3.27's in my 8.8 rearend(just did it yesterday), I was following my friend and he was doing 60-65 on the hwy, my speedometer said we were doing 80.
Old 07-15-2013, 09:21 AM   #7
on older v6's you cant tune it to fix the speedometer, you have two choices. You can install a different speedo gear (if your car is gear driven 99+ are no longer gear driven). The second and better choice regardless is to get a speedcal unit to correct it, easy to install (plugs in between the trans and computer to modify the signal to correct for your gears vs stock gearing.
The issue is just to make sure its compatible with your year/trans
Old 07-15-2013, 09:33 AM   #8
Which one of these options is cheaper?
12:37 PM
