Front bumper hangs low - Mustang Evolution
Old 07-15-2013, 06:31 PM   #1
Doubledeee99's Avatar
I bought the car with the passenger side bumper not connected to the car. It kinda hung off about 3 inches. I tried putting new screws on that side & it lasted for a little but it still hangs off.
Now I discovered I'm missing helllla clips under the hood(a year & a half later) I've been to junk yards to find the clips but can't anywhere. I just want my whole front end flush with the hood, any suggestions or maybe the problem?
Doubledeee99 is offline   Reply With Quote
Old 07-15-2013, 06:33 PM   #2
samuelsmith's Avatar
I used screws. Post pics.
Old 07-15-2013, 06:45 PM   #3
The screws dont keep it connected it just falls off so I have to fix it everyday lol
ID:	118510   Click image for larger version
Old 07-15-2013, 06:54 PM   #4
I had to put a energy absorber in mine. But, the whose bumper sagged especially across the area where the tag mounts up.
Start easy check the clips underneath that mount to the bumper.Also the black plastic that mounts behind the bumper. It goes all the way across to the lights. May be cracked. You can use fiberglass to hold the bumper there.
1999 2004 Ford Mustang Rear Bumper Bar Energy Foam Impact Absorber Isolator | eBay
Old 07-15-2013, 07:09 PM   #5
sam62893's Avatar
Maybe the front nose panel is broken?
Old 07-15-2013, 07:33 PM   #6
Blovett55's Avatar
Man that's bad, how disaligned is the passenger headlight, looks like its just kinda hanging there
Blovett55 is offline   Reply With Quote
Old 07-15-2013, 07:41 PM   #7
There is missing clips everywhere. I haven't looked too deep under the hood yet but the visible ones are gone. Both headlights are missing the clips that keep them in place. There is a total of 4 and I only have 2...I have seen any cracks or splits so I need to get a better look inside.
---------- Post added at 06:41 PM ---------- Previous post was at 06:39 PM ----------
& they hang like an inch away from hood. When I lift the front bumper it looks perfect then let go and it falls down
Old 07-15-2013, 07:45 PM   #8
Blovett55's Avatar
The clips for the headlights are fairly simple, on our black mustang my dad broke the passenger clips, can wire tie them in, or he took some pencils, wooden #2 type and broke them so they wer short enough and stuck in the harness
Have you looked into maybe drilling a few holes, put bolts through the bumper and a nut on other side so it won't just slide off like the screws, just until you get clips
Old 07-15-2013, 08:25 PM   #9
NewMtang's Avatar
It took you a year and a half to figure out something was wrong? Your not a Ford mechanic by chance?
Old 07-15-2013, 08:28 PM   #10
I'm gonna have to try the pencil thing! I can hellla see it working.
I already tried putting new screws in because the old ones were stripped and they just came out when I hit a pot hole like two weeks after tried that, and since then I just gave up.
---------- Post added at 07:28 PM ---------- Previous post was at 07:26 PM ----------
No I knew something was wrong I just started doing other things to my car and left it alone until now...
No I am a 20 year old female who sells guns so no I am not.
Old 07-15-2013, 08:31 PM   #11
Blovett55's Avatar
Guns!
I think I'm in love
Lol
Yea I'm saying instead of running screws through it again, run some small bolts, and nuts on the end so the bolt won't come out of the bumper like the screws are
Old 07-15-2013, 08:38 PM   #12
Ill try it but do you think just that will lift the whole bumper? When I have someone hold that side the front is still low. I hope the clips & bolts together help!
Everyone says they don't notice it but they also don't drive a mustang lol
Old 07-15-2013, 08:48 PM   #13
Blovett55's Avatar
Ha yeah we baby our cars, maybe more than we should, but it's fun
I think if you run a few bolts, spread out through the whole front bumper should work
So wel use this pic of mine as an example, I'd say 1 bolt on each outer side of the bumper, then depending on middle sag I'd put one about where the lights are on each side and if you want to be safe 1 in exact middle
So 4-5 bolts, and a jack so you can get under the car, since you won't want bolts sticking out everywhere
Old 07-15-2013, 08:57 PM   #14
Fun, expensive, and addicting! Lol
Ill have to try that and hope it works! Im going back to the junk yard bc the dude said he was getting a mustang in, would you recommend getting the clips along with the bolts? Or say **** the clips just go with the bolts...
Old 07-15-2013, 09:13 PM   #15
andregayola's Avatar
i said f the cups n bolts n get a new bumeper lol that's just me and nice mustang i like the color
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 07-15-2013, 09:26 PM   #16
I was hella gonna get a new bumper but some dude i talked to at a local shop said getting a new bumper wasn't going to fix it...but might as well and if its still messed up I can just go from there...
My plan was to fix the problem then get the bumper. But might as well have a sick bumper to fix then my ugly one now haha
Old 07-15-2013, 09:35 PM   #17
well what i would do it take he bumper off completely and check around the front to see any metal or nothing out of place and then check ur bumper cover to check for any warping or discrepancy that may be causing it to have that gap
has the car been in an accident before that u know of sometimes when u crash Or hit something it can cause things to move or be shifted to the wrong area just check ad i you don't know what ur looking at ask a local shop
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 07-15-2013, 10:15 PM   #18
If I don't know what I'm doing I always research it. Now a days there is so many videos you can almost find anything. Ill have to check that out. I thought about it, but my luck I won't be able to put it back on lol but looking at my passenger side the metal piece on the car that the bumper hooks on to is definitely not straight. It like curves...
Old 07-15-2013, 10:37 PM   #19
sam62893's Avatar
By any chance, do you live in nor cal? Hahah
But yeah check your nose panel. It could be broken as well that could be making your headlight like that. And just try zip ties and get a body shop to fix it. If they can't they how do they call themselves a body shop?
Old 07-15-2013, 10:47 PM   #20
Both headlights are like that, does that matter? Ill check it tomorrow though, body shops are a freakin rip offff & I'd rather do it myself. Yes I dooo, unfortunately lol Brentwood Oakley Antioch area.
Old 07-15-2013, 11:00 PM   #21
sam62893's Avatar
Yeah, the nose panel holds them in. Mine is broken on the lefts side and my bumper sticks out and the headlight sags. "Hella" that gave it away. My cousins up in frisco say that all the time
Old 07-15-2013, 11:14 PM   #22
Ohh well I'm thinking that's the most logic explanation to why it sags. Wish it wasn't night time right now lol
hahahaha yeaaaaaaah "hella" is a Cali thing! And I LOVE it(:
Old 07-15-2013, 11:41 PM   #23
sam62893's Avatar
I'll post pictures of how mines damaged and we'll see if it matches yours then maybe that could be your problem. But not till tomorrow haha. It's a Nor Cal thing though, I've never heard anyone in SoCal use it :p
Old 07-16-2013, 01:16 AM   #24
Thanks dude, that's nice of you! I hope it's that, they are hella cheap & looks easy to put on. I tired looking at it when i got home but it's too damn dark, ill have to do it tomorrow lol & that's because people in SoCal aren't cool like us NorCal folks!
Old 07-16-2013, 01:39 AM   #25
Tyoung68's Avatar
Hey now not every nocalian says hella but hella people do say it. Im out here in concord
Old 07-16-2013, 01:47 AM   #26
Hella people do say it but I think we say it more then the rest of the states put together lmao coooncorddd?! I'm always out there, I was born and raised in Antioch!
Old 07-16-2013, 11:01 AM   #27
Crowned1's Avatar
diggin the clear corners btw
Crowned1 is offline   Reply With Quote
Old 07-16-2013, 11:05 AM   #28
Blovett55's Avatar
Yea new bumpers are only like $200 from am I think
Old 07-16-2013, 12:45 PM   #29
Thanks! That's why I bought them. I wish they were darker though.
& I don't know if I really like any of them on American Muscle. I was thinking just repaint mine now, put fog lights in & a chin spoiler.
Old 07-16-2013, 12:53 PM   #30
Blovett55's Avatar
My smoked I feel are fine, just need hids now cause light output at night isn't the best
My green vs my buddies stock lights
Old 07-16-2013, 03:52 PM   #31
I just feel like the head lights aren't as black as my tail lights so I thought maybe tint them. But I get what you're saying at night that's why I haven't haha but nice car, i love the color of your mustang! At night its probably sexier lol
Old 07-16-2013, 03:59 PM   #32
ID:	118728 Click image for larger version
ID:	118729 Click image for larger version
here are two syringe day and one at night at night u can barely notice my car in the shade
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 07-16-2013, 04:08 PM   #33
Blovett55's Avatar
Yeah the perks of a mustang with only 3000 that color, it stands out
Lol
I wouldn't shade them, what VHS niteshade does, I presume that's what u use, actually basically spray paints them black, so every pass with the paint is actually knocking your vision distance down more and more, there's a reason they only tint headlights to a certain point, after a certain point it's less sexy and more of a liability for them, trust me I'd love to have mine completely flat black
My rear end is even sexier, in my opinion
Lol
(Especially when the sequentials are going)
Vs
Old 07-16-2013, 04:19 PM   #34
I bought them already like that. The only tint I did myself was the side markers and 3rd tail lights. I bought the tint from American Muscle and I was going to buy it for the head lights and try it??
And I'm digging the front end more! But it's still sick!
Old 07-16-2013, 04:36 PM   #35
Blovett55's Avatar
Well are yours tinted or just clear side market?
07:48 AM
