How bad is this dent? Worth taking out? - Mustang Evolution
Old 07-17-2013, 09:15 PM   #1
skylaar10's Avatar
Well on the way home from Florida (to VA), my Mustang got hit while I was sleeping at a hotel in Georgia. I didn't notice it until I was almost back in VA.
Insurance still has a $500 deductible... should I take it somewhere to get the dent popped? Can a dent like this even be popped out?
I don't know how expensive it would be, either lol.
ID:	118978   Click image for larger version
skylaar10 is offline   Reply With Quote
Old 07-17-2013, 09:22 PM   #2
slow281
sixpac's Avatar
Region: Nebraska
That's right ware the inner panel meets the quarter panel.. It's probably a bondo and paint..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-17-2013, 09:32 PM   #3
skylaar10's Avatar
Bondo is like a putty right?
Old 07-17-2013, 10:13 PM   #4
sam62893's Avatar
This is bondo. It's a brand of plastic filler. It's like the Band-Aid of bandages. It's a tricky process that involves sanding and stuff. If its a $500 deductible I say do more damage and have them fix more
Old 07-17-2013, 11:34 PM   #5
skylaar10's Avatar
Haha how much is that stuff?
Old 07-17-2013, 11:38 PM   #6
2300turboford's Avatar
Not real expensive labor is what gets you
Old 07-18-2013, 12:10 AM   #7
Tyoung68's Avatar
Take it to a body shop and see what the quote you if its more than like 7-800 then id have insurance take care of it but if its less than slap some bondo on and sand and prime it and then take it some where and have them paint it. To do bondo its a little tricky but you should be able to handle it. Its usually about a quarter size of hardener to bondo mix well till its all one color and then let it dry a little but not till its hard and shape the bondo with like 80 grit sandpaper and then wait for it to dry ad where needed then go over with 220 and then get some high build primer spray it on kinda thick to fill all air bubbles in the bondo and if there real big bubbles then get some spot putty or mix up a little bondo and repeat previous steps and then you can go over with sand-able primer and go over with 220 and work your way up to like 1000-1500 grit paper and then if you want to see how you did with it get some high gloss spray paint and put a couple coats on and see how well you did and if it is acceptable take it to the body shop and have them match it to the rest of your car
Old 07-18-2013, 07:13 AM   #8
mummert_96v6's Avatar
There's a tool out that can just weld a little like tab on to the spot. Then you put a slide hammer on the tab and just pull the dent out. So if you could find one of them you wouldn't need to use as much bondo
mummert_96v6 is offline   Reply With Quote
Old 07-18-2013, 07:26 AM   #9
leave it, its just character.
Old 07-18-2013, 07:27 AM   #10
Region: Iowa
I use stuff called kitty hair, it's a fiberglass material but won't crack like bonding can but u need to sand to bare metal then to fill the pin holes mix fiber glass resin and bondi hardener together will dry fast if humid out but just smooth it on fast . Then at least to coats of primer then sand and paint
Iowaboy13 is offline   Reply With Quote
Old 07-18-2013, 09:20 AM   #11
sam62893's Avatar
I took some body shop classes at my community college. We call it a stinger. You have to grind down the area to bare metal, weld some tabs on there an pull it out, then plastic filler, sand, repeat, paint, etc. couldn't even finish my project it was too time consuming and a large margin of error. Especially where the damage is, that's the worst spot I had to deal with on mine. You have to line it up just right then make the lines even. It's a PITA trust me. I'd rather spare myself a headache pay to get it done. Here's an example of what you have to do. I ended up jut sanding the car down and shooting the whole thing with primer
ID:	119032   Click image for larger version
ID:	119034   Click image for larger version
Old 07-18-2013, 09:20 AM   #12
sam62893's Avatar
Old 07-18-2013, 09:28 AM   #13
My cars got a bad dent in it to I slid off the road not long ago bent an axle put a dent in the door and rocker panel. Here's some pics of it. A friend of mine has the stinger so I'm gonna try that
ID:	119039   Click image for larger version
Old 07-18-2013, 09:30 AM   #14
sam62893's Avatar
Ouch, that's gonna take some time. And patience, you need a sort of clamp because you need to put studs all along that dent. You can't do one by one because it'll come out uneven. Good luck!
Old 07-18-2013, 09:35 AM   #15
I'm probably just gonna replace the door and worry about the dent in the rocker
Old 07-18-2013, 12:17 PM   #16
Tyoung68's Avatar
They sell a stud welder and slide hammer kit at harbor freight for pretty cheap
Old 07-18-2013, 06:23 PM   #17
Yea I checked on it for the stinger tab welder an the slide hammer is only $100 so ill probably buy that. Thanks for the info
Old 07-18-2013, 07:49 PM   #18
Tyoung68's Avatar
No prob i actually work there. You can get a 20% off coupon and j recommend getting esp on them
Old 07-18-2013, 08:01 PM   #19
Tyoung68's Avatar
03:26 PM
